BaSs_I_LoVe_YoU
Urgent!
hey i have a couple last minute questions!
i need to cut a hole for the sub to fit in! On the Fi web site i have a Bl 15" does the CUT ID: 14.125" mean thats the size of the hole across i cut??
and for the port i should screw those into the box on the top and bottom not just glue right??
Thanks!
-Ryan
yep thats across..
not sure what you mean with the port? if you plan on making it removeable then don't use wood glue, if you plan on leaving it alone then glue it in.
Ryan R, just curious, where do you live?
yea that was a bit confusing.. im mean like you have a port..and the piece of goes back into the box...you glue that in and screw it in right?
in a nut shell, yep
