youngstunna
no replys to emails
scott ive been trying to email you about cutout sheet for box you designed me and i havent heard a from you so i guess ill try on here and this is the email you sent me with the box specs so it should be easy for you to help me out :D and its for the box with the sub up and port back thanks
To: "jamal martells" <[email protected]>
Subject: Re: box question
Date: Sat, 9 Jun 2007 13:49:56 -0700
Im assuming it is for a 15" sub given that it is 3.5 cuft. From the dimension the only way to fit the sub is firing up. I will give you designs for both rear and up firing ports... you can choose which works best for you.
Up firing port and sub: 31" Wide X 15" Tall X 21.5" Deep. Port is 2" X 20" (inside of box depth) X 30" long. This nets you 3.5 cuft after port and driver displacement tuned to 28 Hz.
Up firing sub and rear firing port" 31" Wide X 15" Tall X 21.5" Deep. Port is 3" X 13.5" (inside height of box) X 32" long. This nets you 3.5 cuft after port and driver displacment tuned to 28 Hz.
Please let me know if I can help with anything else.
Thanks,
Scott
Fi Car Audio
