BaSs_I_LoVe_YoU
Did i jack up?
i have a quick question...
i bought a dual 2 ohm Fi BL
i want to wire in to 1ohm so i can get 1500wrms out of the SAZ-1500D to the sub
can i not do that..can i only wire the sub to 2 ohms not 1ohm??
Edited by Ryan R
A single Dual 2 ohm speaker can be wired to a 1 ohm or 4 ohm load.
A single Dual 1 ohm speaker can be wired to a 0.5 ohm or 2 ohm load.
If you're using multiple speakers, then the possibilities grow from there.
Dual 2 ohm sub can be wired either to 4 ohm (series) or 1 ohm (parallel). You could also of course only excite one of the two coils with half the power of the subs ratings and have a completely different sounding woofer as well-yields a 2 ohm load.
It couldn't have taken me two minutes to type that....but DD's response wasn't there when I started.
voice coil (1) positive to voice coil (2) positive. voice coil (1) negative to voice coil (2) negative. basically run a wire from red to red and black to black. then run a red wire from one of the red terminals to the (+) side of the amp. then take a black wire and connect it to the negative (black) on the same side as you connected the (+) to and run it to the (-) side of the amp. if you need more assistance go to crutchfieldadvisor.com and go to woofer wiring options.
You beat me to it.Also explained it.What he said ^^^^^^^^^^
