mlstrass
1500D's Strapped
I'm running 10g wire for the POS connections and had a hunk of 4g laying around, so I used that to connect the NEG terminals.
Any problem with running bigger wire for the NEG connections?
Maybe I am reading this wrong, but how did you connect 4 gauge wire to the speaker terminals?
Probably looks weird but it won't hurt anything by running a larger negative wire in this case.
power comes in and power leaves.
The bigger wire is better regardless, it would have the same effect if u put it on teh pos.
Nope, you read right. I just twisted the end VERY tightly and it slipped right in. The terminals on those amps have around a 1/4" opening, so that's why I tried it. And I had the wire just collecting dust.
The "dirty" side of this install doesn't look pretty, but is functional. I'm only worried about making the cabin look clean. I always hear that ugly is loud, so I want to find out ;)
If you can fit it in there, it will be fine.
I use 4 on mine...
