BigOso
DC Audio subwoofer levels and specifications
Level 2
10" 12" 15"
Mounting Depth 5.5" 6" 7.5"
Mounting Hole Diameter 9.25" 11" 14"
Motor Width 6.5" 6.5" 6.5"
Weight 18lbs 18.5lbs 19.5lbs
VC Diameter 2.5" 2.5" 2.5"
Magnet Weight 15lbs 15lbs 15lbs
Power Handling RMS/Peak 300/600 300/600 300/600
Impedance D4ohm D 4ohm D 4ohm
Sd 334.00 cm^2 519.00cm^2 872.00cm^2
Vas 36.40 L 73.90 L 145.10 L
Cms 2.33e-04 m/N 1.96e-04 m/N 1.36e-04 m/N
Mms 93.47 g 131.94g 168.60 g
Fs 34.1 Hz 31.3 Hz 33.2 Hz
Bl 20.89 N/A 20.89 N/A 20.89 N/A
Re 7.20 ohm 7.20 ohm 7.20 ohm
Qms 4.31 6.68 7.88
Qes 0.49 0.53 0.58
Xmax 18 mm 18 mm 18 mm
Sensitivity 86.5 dB 88.2 dB 91.5 dB
Edited by BigOso
Level 3
10" 12" 15"
Mounting Depth 6.25" 6.75" 8"
Weight 19.5lbs 20lbs 21lbs
VC Diameter 3" 3" 3"
Magnet Weight 17.5lbs 17.5lbs 17.5lbs
Power Handling RMS/Peak 600/1200 600/1200 600/1200
Impedance D 4ohm or 2* D 4ohm or 2* D 4ohm or 2*
Sd 487.00 cm^2 494.00 cm^2 791.00 cm^2
Vas 32.10 L 74.15 L 162.80 L
Cms 9.67e-05 m/N 2.17e-04 m/N 1.86e-04 m/N
Cas 2.29e-07 m^5/N 1.16e-06 m^5/N
Mms 242.06 g 145.73 g 198.55 g
Fs 32.9 Hz 28.3 Hz 26.2 Hz
Bl 22.18 N/A 22.18 N/A 22.18 N/A
Re 5.80 ohm 5.89 ohm 6.10 ohm
Le 5.06 mH 5.06 mH 5.06 mH
Qms 5.21 8.11 8.40
Qes 0.59 0.59 0.71
Qts 0.53 0.55 0.65
Xmax 22.5 mm 22.5 mm 22.5 mm
Sensitivity 84.70 dB 86.40 dB 88.0 dB
* There will be a $25 upgrade charge for high performance dual 2ohm coils.
Level 4
10" 12" 15" 18"
Mounting Depth 6.25" 6.75" 8" 9"
Mounting Hole Diameter 9.25" 11" 14" 16.75"
Motor Width 7.75" 7.75" 7.75" 7.75"
Weight 31.5lbs 32.5lbs 33lbs 35.5lbs
VC Diameter 3" 3" 3" 3"
Magnet Weight 28.5lbs 28.5lbs 28.5lbs 28.5lbs
Power Handling RMS/Peak 1000/2000 1000/2000 1000/2000 1000/2000
Impedance D 2ohm D 2ohm D 2ohm D 2ohm
Sd 314.00 cm^2 494.00 cm^2 791.00 cm^2 1159.00 cm^2
Vas 27.40 L 66.60 L 160.00 L 260.90 L
Cms 1.99e-04 m/N 1.95e-04 m/N 1.83e-04 m/N 1.39e-04 m/N
Mms 115.70 g 173.08 g 211.60 g 218.61 g
Fs 33.2 Hz 27.4 Hz 25.6 Hz 28.9 Hz
Bl 16.15 N/A 16.15 N/A 16.15 N/A 16.15 N/A
Re 3.60 ohm 3.60 ohm 3.60 ohm 3.60 ohm
Le 4.02 mH 4.02 mH 4.02 mH 4.02 mH
Qms 5.15 5.13 6.07 6.55
Qes 0.43 0.42 0.47 0.70
Qts 0.40 0.39 0.44 0.63
Xmax 23.5 mm 23.5 mm 23.5 mm 23.5 mm
Sensitivity 85.50 dB 87.0 dB 89.4 dB 91.4 dB
Edited by BigOso
The subs are built in Sparks, NV. As for Box recommendations DC is currently wqorking on that. If you need any help with boxes for the subs give me a pm and I will help you to the best of my ability.
Is the sensitivity rating in 2.83V or 1w/1m form?
