http://www.woofersetc.com/index.cfm?fuseac...Product_ID=3637
or
because the specs of the tc-7 are here
http://tcsounds.com/tc7.htm
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=4450
this would work for the large ported box under low extension
so pretty much the first ported at 1cu a chamber
the obcon in the picture at 1.4 a chamber
or the large ported for 1.7 a chamber which would give me low extention
i waned 12's but they would be to big for my hatch. i listen to rap and have a small 2002 civic si hachback.
and i want a quality system, but the thing is that because these are 10's i am afraid they wont get loud enough
the power will be from this Hifonics BXi 1606D
can i get any feedback on what to do, as i am really confused
Those subs will get loud enough, but my suggestion would be to go with the tc9's if you want a solid ported driver, or tc1k's which work very well in most boxes. There is of course the tc 10" oem which I have and love. And that sub would love 1 cu. foot per chamber and get loud for you.
tc7 is great in a sealed box. You can put it in just about anything larger than a cube and you dont even have to worry about EQ. It doest quite have the BL to do well in a vented system compared to a TC9. If you're going vented, go with 9 otherwise the TC7 is really unmatched in a sealed box as far as ease of install and linear response ie: SQ. as far as TC drivers go.
I agree, my old Eclipse TC-7 based drivers are awesome sealed. They have taken a beating for years and keep on trucking.
well the only problem is that i can not find a good prefab box built to the specs of this sealed.
build your own?
i would but i have nothin to cut out the sub hole
not to mention id be afraid of messing everything up. haha
Use a jig saw for the sub whole, and fiberglass and ductape are your friends. Not to mention caulk and several other methods for sealing up messed up cuts.
PM mrray13 and see what he can do for a box for you.
