bassmachine
maintaing power
Ok here is something I came to. People buy the most exspensive batteries and high output alternators, and still experience voltage drop at 11 volts and steady decline. :puzzled: What do most people do to solve voltage drop.
Turn it down? :D
You have to ask yourself how much drop is acceptable, and size everything to meet that goal...
If you're dealing with a lot of power, sizing the system to eliminate all voltage drop could get expensive. There's a reason why dB Drag guys have 16 or more parallel runs of cable; fractions of a volt lost could be what makes a first place into a second. So unless you're chasing that kind of diminishing returns, ultimately you're going to get to a point where some voltage drop is acceptable.
oh yea i understand that, I know THE is going to happen regaurded less, but what im saying is whats the best way to prevent that from happening, I want 2 stay at 12 to 14.4-9 volts.any tips besides batts, and alternators.
Multiple runs of heavy gauge wiring, and solid connections.
