aarunt1
Claw mag sealed box suggested volume/mounting depth
What was the suggested volume for the Claw Mag in a sealed box. I think it was 0.5 - 1.5, what do you guys suggest? Also what is the mounting depth for the claw mag? Thanks!
.75-1.3
That should yield you some great results. I personally would do about 1.25 stuffed and call it a day. If you go smaller, throw a little extra power at it. Mounting depth should be slightly less than the current driver as the TC9 was not nearly as deep.
Well my amp is 1200w rms so Ive been pushing it in about a 1.75cu ft box and it just seems like its too big and the sub doesnt seem to handle it all the time so I want to go smaller. I hope about .75 cf with some polyfill will be good I want to put it in the cabin of my car now instead of the trunk so the smaller the better
Edited by aarunt1
Easiest way to find out what'll work best is to add stuff inside your current enclosure to take up space. Once you get it down to where you like it, build a new enclosure of said volume.
