bsmallard15
PLEASEEE HELP
I recently ordered a 1 ohm 12 Q and a Orion XTR PRO 1000. At 1 ohm the amp is supposed to give out 1000rms. How will i wire this sub to the amp, and will this sub run well with this amp as in pushing maximum power. Thank you.
Im a noob lol soooo i prob sound super stupid.
EDIT***GO TO THE BOTTOM POST.
Edited by bsmallard15
You ordered a Dual 1 ohm ?
If so you can't get 1 ohm out of a Dual 1 ohm...
you can only get 2 ohms (wiring in series) or .5 ohm (wiring in Parallel)
If you want a 1ohm load you need to order a Dual 2 ohm and wire the coils parallel
so saying that i need to know if my sub will run maximum power with my amp. And how it should be wired, i dont know way to much about wiring. Like it sounds to me that if i run it at .5 ohm paralell (not sure what paralell is) then ill be getting even more power to my sub becaues at 1 ohm on my amp it gives out 1000rms. If so do you think this could blow my sub?
That amp doesn't match that sub well. You should have ordered a D2 sub.
soooo what should i do to get the most power out of the amp. becaues i just orderd the sub and it just got shipped.. sooo?????
someone pleaseee respond asap i ordered the dual 1 ohm like 2 days ago and it shipped so if i need the dual 2 ohm i really need to know asap so i can get it shipped back and replaced.
