Jybfan04
Burping Power
What can a SSD take on a burp which is normally 3 secs at most...
I am looking to run a pair of Saz-1500d's strapped on my ssds and would like to know how many watts can they take on a burp....
I was thinking probably 1600 watts per sub but would like to know before hand..
When you break them that was too much :).
Honestly man it's 100% install dependent...there is no say that it can take a certain amount of power for a burp.
some might frown on this but this is the way ive always done it,,,if the power is clean and you know your freq.and you arent burp happy 3-4 times your RMS,unless i have money to spend or extra gear laying around ill toss an obscene amount of power to it
thats what im thinking and the power will be clean of course I wouldn't even think about burping it with that kind of power unless I was sure I had the electrical to do it...
but I was thinking 2 times the rated power and the sub would be fine....
I need to get my spl scores up....
:takepix:
Simply adding more power to the same driver is about one of the worst ways to get your score up.
Of course that is the last option and me and a friend have been toying around with burping MY subs with 2wice its power rating to see what I can do on the meter...
Of course this is after I redo my enclosure and tune higher so I can burp at a higher frequency which tends to be better for the subs...
Put it to ya like this I do a 140.4 right now at 38hz with my 2 12" ssds with copper coils....
If I go any higher (frequency) currently with my enclosure the scores go down....
I jus hope I don't blow them but its jus been something I been thinking of down jus haven't made it a definite yet...
:coolugh:
depends on your equipment,lets take my current setup,2 Atomic apx,im doing the higest # i can do possible with my set up at what little power i have,so now im adding power,but ive already built the best enclosure for my application,worked on my electrical...all i have left is power,held true when the Crossfire BMFs where in the crx,not the strongest drivers 350rms if i remeber right,,but i was burping them with 2 modded Vr 2000s,but again did everything i could with what i had before the power,so what Jim says is correct,BAH!!nevermind im rammbling now,,lol just add more power and turn it up,,muuhahahaha
http://bigbassman.realmofexcursion.com/images/graphs/spl.gif
Lloyd gave an SSD @ 52hz over 2k watts on a SPL burp.... And it scored in the top 4 of the challenge...
BUT i don't know the specifics of the install but lloyd did tell me that it was a single woofer in an spl optimized box, with a non-killing power in a rex..
as nick said it is install dependent.....
Fi subs were in the top 7 out of 26 tested. This is just one part of what they did LOL.
there is more results that showcase Fi subs and how they performed....
http://bigbassman.realmofexcursion.com/collective.htm
Also anyone notice the SSD did better numbers then the Q with less wattage ?
The SSD is not Fi's bottom line... it's just different model (i know nobody here said that but i read it in a few posts before)...
Needless to say its because of that challenge that I even know anything about FI...
and I was impressed with the scores the SSD did and the pricing which to me equaled a good darn reason to try out the product and I have been satisfied thus far.
