Guest PatRICK
btl 18 help
Guest PatRICK
i just bought a fully loaded btl 18 i need the specs on the optionl things like xmax mounting depth and displacement anyone know?
From the website:
"BTL18
DUAL 1 | DUAL 2
Fs: 32.6 Hz | 32.1 Hz
Re: 0.7 Ohms/coil | 1.5 Ohms/coil
Qms: 6.11 | 6.20
Qes: .28 | .26
Qts: .27 | .25
Mms: 298g | 307g
Cms: 0.80mm/N | 0.80mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 164.2 l | 164.2 l
Spl: 94.9dB 1W/1m | 95.1dB 1W/1m
Bl: 17.5 N/A | 26.9 N/A
Bl: 00.0 N/A | 00.0 N/A
Xmax: 16mm * | 16mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-8cuft | 5-8cuft
Sub OD: 18.500
