nate2587
Recone Pricing info
Ok, well i sent and email to [email protected] but i figured that i might just post up on the forum to share with everyone else this information. I apologize about not posting on here first as i read the sticky AFTER i had emailed you guys.
1. Do you sell Recone kits? (soft parts excluding the basket unless i need it and does it come with glue?lol)
2. What Recone kits do you offer (BTL, BL, SSD, Q, RE SX? ______________ and what else?)
3. How much are each of the Recone kits shipped?
4. Do you have a Shim i could maybe purchase?
5. Could you include more information about the recone kit? ( what size 2" 2.5" 3" do you offer 4"?)
6. How many layers do the Recone kit come with? 8 layer? 4 layer
7. I just need some general information about the recones i did a search for it but it looks like everything was handled in PM
8. Any other information that could be of use that you can include in this email that i haven't already included would be greatly appreciated :)
Thanks,
Nathan
1) Yep, no glue per msds/shipping issues.
2) We sell a recone kit for any of our subs, and normally can do many other woofers...just depends on if its a 3" coil motor or not, and the id/od of the coil. Most of the time on different stuff you have to ship the sub in, we can't build a drop in for it and the vast majority of Chinese motors we simply cannot do (they use a oddball coil size, ours are standard 3")
3) Cost depends on what the recone is, generally varies from 80-110 + shipping (if not more)
4) Shims come with it if we can make a kit for it, if it isn't thick enough you can use paper or even a manilla file folder.
5) 3" only, we're not getting into a bunch of oddball stuff..and we're not in the recone business, if we have something in stock that'l fit the motors you have...sure we'll build you a recone. Otherwise we're not tackling other projects with other size coils now.
6) All depends on gap demensions
Thanks!
-Nick
got a recone kit available on a Blueprint 1003? it has a 3" coil im not sure if you are familier with the driver or not but i guess it was RE made
Yep, almost positive Scott could do that.
Specs probably wouldn't be the same as original, but it would at least work again
