solidcrowd
12" Fi Q and.....
Which amp for great sound quality and build, but the MOST important is efficiency (stock 90amp alt. but doing the big 3 soon) .thankz in advance.
JBL GTO1201.1 II
Apline MRD-M1005
INFINITY 1211A
Kenwood KAC-X1R
Orion HCCA-D2400
PHOENIX GOLD RSD1
SoundStream PCA1500D 200.1
Edited by solidcrowd
Why not get an SSD and run less power?
I thought about that, i was thinking about getting the ssd with copper coils and bp power. But i have a few questions i need to get cleared up, for an example say i have a true 1000watts going into the q and a true 1000watts going into the ssd with copper coils and bp power which one would be louder? and what one would sound better? Also, would the q take more watts to get moving..causing a decrease from getting loud? where the ssd isn't needing as much watts to get moving therefore more output?
Totally dependent on your install.
Dependent on your install, your taste in music and how picky you are.
I don't think you'd have a problem with an amp in the 800-1kW range and a small 50x2 amp for your front stage, as long as you're smart about things...
so should i get the fiq or the fissd with copper coil and bp power? i was thinking i might as well get the q beucase it can handle more if i decide to upgrade, has a more xmax, and the price is so close y not.
I don't think you'd go wrong with either...
I kno thats the problem lol why are they so similar to eachother, ooo00 and i know its all install dependent but which setup will be the loudest n have great sound quality out of these choices:
Basically im looking for a great realiable amp thats super efficient with the most true watts
*90 amp alt, 0 gauge amp wiring kit
*Box probably going to be 2.2 @ 33hz (its in a 99 saturn sl2)
Fi Q or F i SSD copper coils, BP power
and with what amp?
JBL GTO1201.1 II 1114 X 1 2ohm 115 amp 3X40fuses
Apline MRD-M1005 1000 X 1 2ohm Heard only draws 90 amps
INFINITY 1211A 1300 X 1 2ohm
Kenwood KAC-X1R 1200 X 1 2ohm
PHOENIX GOLD RSD 1200 x 1 2ohm
My very first choice was the fi q and the apline, n now im thinking the phoenix gold
Please pick what combo you think would fit my application, i want to get this project done
They all look like more then capable amps.
I would choose the amp with the best features on it like subsonic filters, crossover, connections, and others.
I might vote for the Q and maybe check out the new Sundown SAE-1000D's.
