deftones05
Trouble shooting advice
I just put my system in my car from the old one and I've had a bit of problems. Its a small system and only 1 10"sub and 1 amp powering the sub.
The amp has power
i've tried wiring the sub for r +, l - and r -, l + on the amp
The sub setting on the deck is on and set to max
The sub doesn't get a signal, doesn't hit at all
Any ideas on what i can do next to figure out whats going on?
Thanks alot
Edited by deftones05
is the sub single voice coil or dual?
also, is the amp a monoblock, 2, or 4 channel?
about the best you can do is bridge one side and run that to your sub. You'd be better off grabbing another sub or amp
what interconnects are you using?
