Loudon22
optimal power for the ava?
I have an ava 15 ... and i wanna know what kind of power i should put to it ... right now i have a kx1200 that i could run to it but im afraid with that power in 2.5 sealed enclosure it might be to much ... any suggestions? maybe a dif amplifier?
i'd go with 800, hell i could power my tweets off that amp, its not about the power, it's about setting your gains properly and being careful with the volume.
Go down to 2.0 cubes even and you'll be fine. Thermal power handling is not the issue here; it's keeping it within mechanical limits.
thats what i was thinking ... for now i might keep it in the 2.5 til i can get a new box ... looking at 4.0 tuned to 28-30 hz since the fs is low
The 18s are a bit heavier than the 15s, but I fed my Avalanche 18s 1300+ each for over a year and never once bottomed them out.
Of course, it wasn't a constant 1300 because its music, but clipped or unclipped, they got 1300 frequently wether they liked it or not.
Edited by Duke
Dave would :D
i have run both the bx1000d and bx1500d from hifonics to my 15ava. in a 4cuft 28hz box. the 1500d wired at 1ohm seemed to be a little much for it at a high volume. it starts to make a funny smell. the 1000d (curently using) seems to be a much better fit. i can play it as loud as i can tolerate for extended amounts of time with no problems at all. hope this helps....
