dopey
Is this a good 15" BTL Loaded enclosure?
39" wide
18" deep
22" tall
1.5" walls
4.5 box volume
76sq" of port
32" long port
tuned to 34hz
With available space, I'm tuned a little high (it's a big interior, peaks around 40hz)...and I'm lacking port area.
Should I go longer on the port to get lower or should I go longer and wider and keep the tuning freq (or possibly let it raise)?
Edited by dopey
Why are you doing 1.5 walls.
If anything, just do a double baffle.
Also, I think you forgot to include the port wall as part of displacement... just and :fyi: no biggie.
I LOVED mine in 4.5 @33hz with 90 sq. in. of port.
nG
NOOOOOOOOOOOOoooooooooooooooooooooooooooo............
j/k
If you want double walls good. If this is for daily I'd tune a little lower. I have mine tuned around 35hz and I wish I was tuned just a little lower (32hz-ish), although it still sounds great. If this is for daily I can't see why you'll have a problem with it.
as far as port area fi recommends 12-16sq per cubic foot. 16x4.5= 72sq, so you would seem to be good. Just bevel the ends of the port, and again, I'd tune a little lower. Good luck
