followyoursole
just ordered 2 maw-15's
I just order 2 maw-15's from the sound solutions shop. I gonna run them sealed and power them with a hifonics bx1500d about 1300-1400 clean watts at 1 ohm to both of them together. How hard do you think they will hit and how loud? Im running a fi ssd ported with the same amp right now but i need more , since my car has bad cabin gain.
Will this set up kill my 12 inch ssd I have now? Im trying to get my setup louder and deeper then a fi q 12 inch ported powered by a 1000 watt lanzer amp. My friend has that setup in his scion tc, and it bangs in that car. I have a 4 door sedan and decided i needed more to get as loud as his. I just hope this is what im looking for. Any Thoughts?
I put your subs out first thing this morning to be picked up by UPS. The 2 15's have a large cone advantage over the single 12. But keep in mind you have to allow a little bit of time for break in.
Also, when you get them play around with placement, and see if you can open/widen an open area into the cabin of your sedan. Also you could try IB later, just watch the gains.
Oh, and would anyone know the exact displacement of each , maw-15? How many cubic ft does the sub take up?
I dont know if the exact number is out there anywhere, But IMO I would acount for them being 0.15 ft^3 in any box calculations.
