Jybfan04
If I wire a 2 subs down on the SAZ 1500d
If I wire 2 subs down each dual d1 coils down to 2 ohms meaning each sub is wired down to 2 ohms does the amp bridge that internally to 1 ohm..
wire the coils in series (down to .5 ohms per sub) and than wire the subs in parallel to get a final impedance of 1 ohm
wire the coils in series parallel (down to .5 ohms per sub) and than wire the subs in parallel series to get a final impedance of 1 ohm
Fixed, again... You might want to get those straight audio-neon, you could really f**k someone's system up if they listened to you and wired something down in parallel when you mean series.
That one, shows my infinite noobishness :Doh:, at least in this case if he had followed my directions he would have wired up instead of down...:dammit:
:thanx: for the correct.
i always forget that parallel subtracts and series adds.
Thanks for the help I kind of knew I had it right I just wanted to double checked to make sure I didn't have any erros because I was prepping for a comp and if you turn to high lets jus say it could have been trouble somewhere especially on the electrical I have.
what is the difference if wiring each sub to 0.5 or to 2 ohm ?
does it matter in some way ? after you connect them both we still get 1 ohm this way or the other , right?
I always wire in series/parallel in this case. So therefore, each subs voice coils in series, and then each sub in parallel to the amp.
I am a little lost about the D1 ohm wiring myself. I want to get two of them, but my box has 2 separate chambers. I can't wire the subs together, so do I just wire each one to a 2 ohm load? + to - and +/- to the amp on each side?
