extremeVFT03
1 18q or 2 12q
the 12's would be louder, but the 18 will hit low notes with more authority, but personally i would stick with the 12's unless you have a really solid mid-bass up front.
By better do you mean spl or sq?
Is there a way you could give one sub that 2kw?
Is space an issue- because you will need more space to make that 1 18 happy than the 2 12s.
Have you definitely narrowed it down to the q, or are you open to the bl?
Can you strap those to give a BL 2000watts?
Truthfully I love my 18s so much the only reason I'd go down is if space is an issue- so I'm biased.
the two 12's will move a bit more air (based in theory off of cone area)....
I do believe the 18 will sound louder and can get LOWER then the 2 12's Given many factors though (enclosure of course and car ergonomics)
x2
effective cone area (Sd) on the 12 is 481cm^2, on the 18 is 1210cm^2.
I just love how deeeep it sounds.
petey,
A sub can play at any wattage under it's rated rms...
People think that when they put little watts to a sub and the sub tends to "flutter" or "bottom out" they immediately think oh it's the sub... and in the case of underpowering they all say "You need more watts to the thing" for the WRONG reasons...
There are many factors to why a sub "sounds" the way thy do given a lower wattage and almost 80% of the time it is due to clipping (the amplifier).... other factors is amplifier efficiency, sub woofer efficiency, enclosure and the cars electrical.
WIll it handle it's 1200 watts being that it may be under RMS
the answer is OF COURSE it will
It may even suprise you (referring to comments like "they are loud and people think i have 15's when i have 12's are all testimonies of the subs efficiency)
I myself did direct swamps with JLw6 and noticed the Fi played much louder at the same volume level
In part it is due to the subs efficiency)..
Now will it be loud enough for you
Only you can answer that question.
see if someone with an Fi can demo for you
note their wattage and sub size and then draw a conclusion based on you ear...
What is loud to ou may not be loud to someone like tej or tpjr
the main point is you want a volume that will keep you satisfied to avoid the humans nature to "turn it up" forcing the amp to clip.... The Fi subs can take it without a doubt, but even superman had a weakness...
Edited by theabunai
