davey242
makin box for S8L7.....
Hey guys,
I'm building a box for a S8L7 sub and had a few questions.
I want to make the largest reccomended sealed box which is .75 cubic feet for this sub.
now, a 12x12x13.25 box with .75 thickness would give me 0.74967 cubic feet which would be dead nuts for what I want.
now is the .75 reccomended volume including the volume that the sub will take up or do I have to make the box volume .75 plus the sub volume?
Also when calculating the wedges, Kicker reccomends a 2x2x.75 wedge. correct me if I'm wrong, but I calculated the wedge volume to be .0017 cubic feet.
Where should I put the wedges? are they required in every corner?
thanx...
dan
Dan, I thiunk that would be more than fine. Sub displacement on the 8" is very small at .034...so if you even want to 'play' with it more, play with a small 1/2 lb. of polyfill. :)
