How to choose speakers to power amplifier?? + connection question
By
DaViD12464, in Amplifiers / Head Units / Processors / Electrical
Recently Browsing 0 members
Recent Topics
- 7 comments
- 434 views
- 1 comment
- 594 views
- 1 comment
- 214 views
- 3 comments
- 1,083 views
- 8 comments
- 2,005 views
- 1 comment
- 164 views
Similar Content
By MJS_IraggiAlts
PRV AUDIO Vocal Speakers....
This may not make sense initially, but a high-quality speaker will have less bandwidth than a lower quality speaker... (for the most part)
Just like a 3- or 4-way system is always better than a 1- or 2-way system. The narrower the bandwidth the speaker must play the cleaner it will sound. This will also keep you from asking the speaker to play up to its upper and lower frequency limits which are where it starts to sound "forced" to play those frequencies
Pro Audio speakers are nothing new to car audio, but I see consumers not really knowing how to properly use them and having some issues which is understandable. These are totally different than your standard coaxial speaker
If you look at the graph on the 6mr500ndy, which sounds amazing, you'll see that it can play from 90hz to 12,000hz... but if you narrow it down to what is plays "best" and more "naturally" it’s closer to 200hz to 10,000hz. Yes, it can play down to 50hz but not efficiently and not as well as 200 and up. Very low volume that would be fine but in what we do with the speaker you will want to cross it over closer to 200-300hz
I get a lot of PMs asking if this speaker will pick up where my subs leave off? … around 60-80hz. I say no but the specs say "yes”. 99-13k so that may be a little confusing if you don’t look at the graph and understand what information it has in it
So, for someone interested in using this speaker as a voice speaker, which I HIGHLY recommend, you will also need a "midbass" speaker to go with it such as a 10mb800 or 10mb500 or 8mb450.
This leads me to another piece of information. PRV model numbers have an "MR”, “MB", "SW" or "W" in between the size of the driver and wattage of the individual speaker. MR=midrange
MB=midbass
W=woofer
SW=subwoofer
This is a general guideline for what the speaker is geared towards. That doesn’t mean an 8mb450 can’t be used for midrange or and 8mr400 can’t be used for midbass. That is where the graph and interpretation of the graph comes into play
There is a lot more that goes into designing your front stage or your "voice" speakers that one of these days I’ll try and have a more in depth write up. The possibilities are endless...
By DedicatedEnthusiast
Hello everyone, long time no see. I am selling a pair of Dual 2-ohm (technically D1.7) 12" Sundown X v.2's built by Dave Leib a.k.a "Strongman Designs."
Reason I am selling them is because I realized upon testing to see if my digital multi-meter was working correctly that one of the coils is reading higher on the one sub indicating that too much heat had been applied to it recently so rather than risking any further damage to it I am going to assume that I have too much power for these.
Having said this in all honesty, let me make it perfectly clear here that both subs are still in perfect working order as we speak, even the one that is reading differently. Had I not thrown my multi-meter on it to test it in order to see if it was working properly (the multi-meter itself) I would have never known there was any difference or discrepancy between the two.
However, because one of them is reading off now and I do not know what is to be expected out of it's performance long-term I will be letting these go for $500+ shipping (that includes both).
Any further questions or concerns please feel free to text me at 440-915-2309
Phil
By Second Skin
In honor of the men and women whose sacrifices provide us with the freedoms that make America what it is, Second Skin is offering discounts on our made in the USA products. From May 26th – May 30th use the coupon codes below to receive 10% - 15% - 20% off your order.
Have a safe and happy Memorial Weekend!
Use the following codes at checkout:
Orders $75 And Up Use: FREEDOM10
Orders $200 And Up Use: HONOR15
Orders $350 And Up Use: AMERICA20
(Shipping Not Included)
WWW.SECONDSKININSULATION.COM
By Jefferson PRV Audio
• Neodymium radial slug motors for extreme speaker control and sensitivity
• Full copper pole-piece sleeve for low distortion and inductance
• Durable cast aluminum frame
A bumped backplate, vented pole piece, vented magnet assembly, Kapton® former, and treated-cloth surround allow for high power handling, while protecting this driver from extreme transient power peaks.
Available now at SSA Store:
http://store.soundsolutionsaudio.com/products/prv-audio-5mr450-ndy-5-inch-8-ohm-mid-bass.html
http://store.soundsolutionsaudio.com/products/prv-audio-5mr450-ndy-4-5-inch-4-ohm-mid-bass.html
http://store.soundsolutionsaudio.com/products/prv-audio-6mr500-ndy-4-6-inch-4-ohm-mid-bass.html
http://store.soundsolutionsaudio.com/products/prv-audio-6mr500-ndy-6-inch-8-ohm-mid-bass.html
http://store.soundsolutionsaudio.com/products/prv-audio-8mr600-ndy-8-inch-8-ohm-mid-bass.html
Recent YouTube Posts
