Aaron Clinton
SSA is now an Authorized Dealer for Massive Audio
Check out all the interesting products here: https://store.soundsolutionsaudio.com/massive-audio/
Some nice bluetooth amps, huge subs, matching rail caps and more.
:fing34:
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 328 views
        • 1 comment
        • 398 views
        • 1 comment
        • 161 views
        • 1 comment
        • 147 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,006 views
        • 8 comments
        • 1,918 views
  • Similar Content
    • By codester
      Been awhile since Ive been on here but I Just purchased back my 2x 15" SSA Icon subs I first purchased around 11 years ago.
      I have/ had them in a 7.2 cubic foot box net tuned to 32 and it sounded great on the bass music and rap/ hip hop I used to listen to but not amazingly accurate/ punchy on rock, etc.
      Im looking to only use one of them in my 2010 Ram 1500.
      I currently have a 10" JL W7 in a sealed box in the truck and it sounds great and I love it but doesn't quite have the output Id like and planning to put 1 of the Icons in the truck.
      Im considering either Ported or sealed. I now listen to mainly bands like chainsmokers, club music, alt rock, heavy rock, and a bit of edm, etc. Looking for it to be very accurate on kick drums but also hit hard so you feel it in your chest.
      According to SSA optimal ported is around 3.5-4 net tuned to around 32hz but Im thinking about tuning a bit higher. Ive done some winisd modelling but its been a long time and just wanting to hear thoughts on these designs.
      My max dimensions are 20" wide, 24" deep by 22" high.
      This is one design i'm considering, is 2.25" wide too thin for port width? im worried about port velocity and noise
      Or if I go sealed this is what im thinking.
      Thanks again for any help
    • By Second Skin
      INDEPENDENCE DAY SALE
      Summer is in full swing and the parties are underway. After shooting off some fireworks and celebrating the nation's birthday this weekend, don't forget to scoop up some American made Second Skin products for your garage project.
      Now through July 6th, take 20% off all products and enjoy FREE SHIPPING to all continental U.S. locations. Use FREEDOM20 at checkout to soak up the savings.
      Don't forget to check out these new products
      Firewall Ceramic Thermal Coating Is Back
      Self Adhesive OverKill Pro 3/8" thick Closed Cell Foam
      Self Adhesive OverKill Pro 1/8" thick Closed Cell Foam
      Radiant Shield Reinforced Foil Heat Shield (1,000 degree F rated)
    • By Aaron Clinton
      We are adding more and more as we get closer to Black Friday.  #crSSAy good prices from the #1source for #authorized online car audio.
    • By Aaron Clinton
      We have finally released our new amp.  It is a tiny tiny production run to see how people like them.  Meant for the high end, SQ market, without the European price tag.  If this model moves as well as I hope, it will help spawn another model in the line up soon.
      https://store.soundsolutionsaudio.com/ssa-dm150-2-2-channel-amplifier-150w-x-2-ch-or-500w-x-1-ch/
      Introducing the all new SSA DM150.2 amplifier. An old school approach, with updated components, for the most discerning of ears. If your front stage is lacking warmth and clarity, its time to upgrade. Our first amplifier in our high-end, sound quality, Class- A/B - Demon amplifier line. The SSA DM150.2 is the elite choice for that high end active front stage, premium passive components, and especially a sound quality sub (SSA Demon). We've incorporated direct inputs for those competition installs that use an external DSP and want their amp to be a pure gain block. Stellar looks to match the design and components. Don't let your speakers or your ears down, #levelup to the all new SSA DM150.2 amplifier.
      150 Watts RMS X 2 @ 4 Ohm 500 Watts RMS X 1 @ 4 Ohm Angled Terminals for show quality installations Full Complimentary low distortion Class AB design Tiffany Style RCA connectorsFull Complimentary low distortion Class AB design Butterworth Crossover Filters for premium level performance An extra pair of input connectors for a direct input that will bypass the crossover so the amp can act as a gain block The op amps featured are TI chips w/BB technology high performance audio grade IC's Docking Pads® to reduce vibration & extend the life the amplifier DC, Short Circuit, Thermal & Overload Protection, on board fusing Diagnostic LEDs Specifications
      OUTPUT POWER @ 14.4V input   RMS per channel at 4 Ohms 150 W x 2 CH RMS per channel at 2 Ohms 250 W x 2 CH RMS Bridged Mono at 4 Ohms 500 W x 1 CH RMS Mono at 1 Ohm N/A INPUT SENSITIVITY 200mV - 6.0V FREQUENCY RESPONSE 10Hz - 30KHz +/- 0.5dB THD LESS THAN 0.01% S/N RATIO > 103 dB CHANNEL SEPARATION > 91 dB DAMPING FACTOR @100Hz 4 ohm > 200 CROSSOVER RANGE   High Pass, 12dB/Octave 80-1.2K Hz Low Pass, 24dB/Octave 10Hz - 250Hz Subsonic N/A Variable Bass Boost (0 to +12 dB bass boost at 45 Hz) Yes Phase Shift (0 - 180 degrees) No Fusing 3 x 40A Size (L x W x H) in 16.4 x 8.9 x 2.2
  • Recent YouTube Posts
