Aaron Clinton
#SSAYardsale
We are blowing out some remaining stock we had left over.  Some killer deals, but most items are 2 or less units left.:
Check it out here: https://store.soundsolutionsaudio.com/ssayardsale/
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 331 views
        • 1 comment
        • 405 views
        • 1 comment
        • 161 views
        • 1 comment
        • 148 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,006 views
        • 8 comments
        • 1,920 views
  • Similar Content
    • By codester
      Been awhile since Ive been on here but I Just purchased back my 2x 15" SSA Icon subs I first purchased around 11 years ago.
      I have/ had them in a 7.2 cubic foot box net tuned to 32 and it sounded great on the bass music and rap/ hip hop I used to listen to but not amazingly accurate/ punchy on rock, etc.
      Im looking to only use one of them in my 2010 Ram 1500.
      I currently have a 10" JL W7 in a sealed box in the truck and it sounds great and I love it but doesn't quite have the output Id like and planning to put 1 of the Icons in the truck.
      Im considering either Ported or sealed. I now listen to mainly bands like chainsmokers, club music, alt rock, heavy rock, and a bit of edm, etc. Looking for it to be very accurate on kick drums but also hit hard so you feel it in your chest.
      According to SSA optimal ported is around 3.5-4 net tuned to around 32hz but Im thinking about tuning a bit higher. Ive done some winisd modelling but its been a long time and just wanting to hear thoughts on these designs.
      My max dimensions are 20" wide, 24" deep by 22" high.
      This is one design i'm considering, is 2.25" wide too thin for port width? im worried about port velocity and noise
      Or if I go sealed this is what im thinking.
      Thanks again for any help
    • By MJS_IraggiAlts
      PRV AUDIO Vocal Speakers....
      This may not make sense initially, but a high-quality speaker will have less bandwidth than a lower quality speaker... (for the most part)
      Just like a 3- or 4-way system is always better than a 1- or 2-way system.  The narrower the bandwidth the speaker must play the cleaner it will sound.  This will also keep you from asking the speaker to play up to its upper and lower frequency limits which are where it starts to sound "forced" to play those frequencies
      Pro Audio speakers are nothing new to car audio, but I see consumers not really knowing how to properly use them and having some issues which is understandable.  These are totally different than your standard coaxial speaker
      If you look at the graph on the 6mr500ndy, which sounds amazing, you'll see that it can play from 90hz to 12,000hz... but if you narrow it down to what is plays "best" and more "naturally" it’s closer to 200hz to 10,000hz.   Yes, it can play down to 50hz but not efficiently and not as well as 200 and up. Very low volume that would be fine but in what we do with the speaker you will want to cross it over closer to 200-300hz
      I get a lot of PMs asking if this speaker will pick up where my subs leave off?   … around 60-80hz.  I say no but the specs say "yes”. 99-13k so that may be a little confusing if you don’t look at the graph and understand what information it has in it
      So, for someone interested in using this speaker as a voice speaker, which I HIGHLY recommend, you will also need a "midbass" speaker to go with it such as a 10mb800 or 10mb500 or 8mb450.
      This leads me to another piece of information.  PRV model numbers have an "MR”, “MB", "SW" or "W" in between the size of the driver and wattage of the individual speaker. MR=midrange
      MB=midbass
      W=woofer
      SW=subwoofer
      This is a general guideline for what the speaker is geared towards. That doesn’t mean an 8mb450 can’t be used for midrange or and 8mr400 can’t be used for midbass.  That is where the graph and interpretation of the graph comes into play
      There is a lot more that goes into designing your front stage or your "voice" speakers that one of these days I’ll try and have a more in depth write up.   The possibilities are endless...
    • By Second Skin
      INDEPENDENCE DAY SALE
      Summer is in full swing and the parties are underway. After shooting off some fireworks and celebrating the nation's birthday this weekend, don't forget to scoop up some American made Second Skin products for your garage project.
      Now through July 6th, take 20% off all products and enjoy FREE SHIPPING to all continental U.S. locations. Use FREEDOM20 at checkout to soak up the savings.
      Don't forget to check out these new products
      Firewall Ceramic Thermal Coating Is Back
      Self Adhesive OverKill Pro 3/8" thick Closed Cell Foam
      Self Adhesive OverKill Pro 1/8" thick Closed Cell Foam
      Radiant Shield Reinforced Foil Heat Shield (1,000 degree F rated)
    • By Second Skin
      Starting on May 1st, Second Skin is giving away 31 pairs of Speaker Tweakers – that’s one winner EVERY SINGLE DAY in May. 62 lucky car speakers are about to sound a heck of a lot better with less back waves! To enter, just go to this page and sign up!
      Enter the Giveaway
      Why are you still reading down here? Get over there and sign up to win!!
  • Recent YouTube Posts
