Mark LaFountain
3rd generation Death Row from Incriminator Audio
Have you looked at the Incriminator Audio Death Row Series yet?!  You are simply missing out if you haven't.  With a 1500w RMS rating, the 3rd generation Death Row from Incriminator Audio. New for 2017, the DR has stepped the game up in the 1500 RMS subwoofer class. Building on the previous generation DR, this new model is the next step up in serious all-around performance. The all-new IA Death Row can work both ends of the spectrum, from the clean and composed daily driving sub with great clarity that can blend well with all kinds of music, to the mega output SPL installs with massive walls of subs. Firmly positioned smack in the middle of the Incriminator sub line up, the Death Row is the Swiss army knife of subs. As it is now an overbuilt design, there is no need to sweat hurting the Death Row. There has been improved cooling and a larger motor to all come together nicely for a stronger all around subwoofer.  #AurhorizedDealer #IncriminatorAudio #ArriveLoud
https://store.soundsolutionsaudio.com/subwoofers/incriminator-audio/death-row/
Features
8 Spoke Black Cast Basket
3" 4 Layer Flat Wound Aluminum Voice Coil
Dual Black Progressive Spiders with Woven Tinsel Leads
Injected Pulp Matrix Fiber Reinforced Cone
Multi-Layer Foam Surround
8.26" 285 Oz Double Magnet Structure with Nickel Finish
688 Oz / 43 Pound Motor Structure
6mm Thick Aluminum Shorting Ring for Inductance
Interlocking Aluminum Spider Spacer Assembly
CILD² - Center Interlocking Dustcap
ADC - Air Driven Cooling
Nickel Plated Push Terminals
Wrap Around Rubber Gasket
1500 Watt RMS Rated
DVC 1 ohm or 2 ohm
