Second Skin
Superlite Coupe (SLC) Build
Sweet new build by customer Cam T. in La Mes, California doing big things with this custom built ride full of Second Skin products. Thanks for insisting on high-quality American made sound deadening from Second Skin Audio we appreciate your continued use of our products throughout the years. Check out his awesome build log here: https://socalslc.com/table-of-contents/
Products: Damplifier Pro, Luxury Liner Pro, Heat Wave Pro, and Thermal Block
#SoundDeadening #SecondSkinUSA #SecondSkinInsulation#SecondSkinAudio #DamplifierPro #LuxuryLinerPro #Spectrum#SpectrumLiquidSoundDeadening
#AmericanMadeSoundDeadening
#SecondSkinForTheWin #TeamSecondSkin
51570561_2705101006167542_39882801740670
51436225_2705101309500845_62314309930650
51645265_2705100982834211_53626117482033
Thermal Block 800 degree thermal deflector
51248345_2705101046167538_49236440573699
Damplifier Pro
51612625_2705101062834203_68515383970313
Luxury Liner Pro MLV + CCF
51144989_2705101092834200_65248525759283
Mega Block 1,000 degree F heat deflector
51737835_2705101119500864_33019182266355
Mega Zorbe Hydrophobic Melamine Foam in the Headliner
51214587_2705101196167523_16469796414344
51332212_2705101219500854_29989781071860
51354321_2705101249500851_37604477497455
Heat Wave Pro in the foot box
51503056_2705101269500849_14165275576453
Very nice work on the install Sir. Just seems like your adding a lot of weight to a very specific designed aerodynamic vehicle.
Cam has built this vehicle from the ground up, every aspect of this build has been thought out, planned out, and executed to his exact preferences. Adding sound deadening doesn't add as much weight as some would like you to believe when used properly in the correct locations and the correct layers. The weight is no different than adding a lightweight girlfriend/wife in the passenger seat. With an engine like he has, I doubt the weight will even be noticeable. His build log is on the first post, I am sure he would love to talk to you about why he did the things he did...he is a very smart and friendly man.
