Mark LaFountain
SSA Hellion (all new)
Hellion definition, a disorderly, troublesome, rowdy, or mischievous person. :+1:
Specs, description, enclosure specs, and options are all up.
Yeah boy just placed order on 3 hellion 10 last night.. I have mids tweets now subs. Soon ill grab amps.
Oh sweet, thank you!!!
7 to 14 day build time, hoping towards 7 days! bought a hellion 12 incher on 12/11. hope to have installed by jan 1st! will post back with pics n stuffs
Awesome, can't wait to see this!
I should probably add that the box is boomtown bt112 single 12" from this site. along with synergy audio efa 1k amplifier from here as well. got knukoncepts 0 guage amp kit with 0 to 4 guage reducers also made by knukoncepts to allow the wire to fit the amp.
should get amp tomorrow.  and then just need the sub and box. feel like mentioning the box and amp is important along with the sub...
That is the normal lead time, and it is business days.  Sometimes during a big rush of a sale or a holiday, it might be a little longer.
I don't see them here.  Was a post deleted?
10" Hellion:
T/S Specs:
  • D4 / D2
  • Fs. 32.5 / 31.7 hz
  • Re 8.0 / 4.0 ohms
  • Qms 4.22
  • Qes 0.45 / 0.43
  • Qts 0.44 / 0.41
  • Cms 0.15 mm/N
  • Mms 212.6 / 210.5 gr
  • Bl 16.3 N/A
  • SPL 86.1 / 86.8 dB
  • VAS 14.1 L
  • SD 320cm^2
  • Xmax 23mm
  • RMS 950 watts
SSA Hellion enclosure info:
  • Overall Diameter 10.5"
  • Displacement 0.12 Cu. Ft.
  • Cut out 9.25"
  • Mounting Depth 6.2"
  • Sealed: .50-1.00ft^3
  • Ported: 1.00-1.50ft^3 @ 28-33hz w/15.25^2 of port per cube
12"
T/S Specs:
  • D4 / D2
  • Fs. 31.0 / 30.7 hz
  • Re 8.0 / 4.0 ohms
  • Qms 4.69
  • Qes 0.57 / 0.53
  • Qts 0.53 / 0.51
  • Cms 0.14 mm/N
  • Bl 16.3 N/A
  • SPL 86.8 / 87.1 dB
  • VAS 44.0 L
  • SD 480cm^2
  • Xmax 23mm
  • RMS 950 watts
  • Overall Diameter 12.37"
  • Displacement 0.13 Cu. Ft.
  • Cut out 11.2"
  • Mounting Depth 7.1"
  • Sealed: 1.00-1.25ft^3
  • Ported: 2.00-2.50ft^3 @ 28-33hz w/15.25^2 of port per cube
15" Hellion:
T/S Specs:
  • D4 / D2
  • Fs. 28.5 / 27.9 hz
  • Re 8.0 / 4.0 ohms
  • Qms 5.01
  • Qes 0.60 / 0.58
  • Qts 0.59 / 0.54
  • Cms 0.14 mm/N
  • Bl 16.3 N/A
  • VAS 88.0 L
  • SD 810cm^2
  • Xmax 23mm
  • RMS 950 watts
  • Overall Diameter 15.5"
  • Displacement 0.16 Cu. Ft.
  • Cut out 14.2"
  • Mounting Depth 8.1"
  • Sealed: 2.25-2.50^3
  • Ported: 3.00-3.50ft^3 @ 28-33hz w/15.25^2 of port per cube
18" Hellion:
T/S Specs:
  • D4 / D2
  • Fs. 25.5 / 24.9 hz
  • Re 8.0 / 4.0 ohms
  • Qms 6.49
  • Qes 0.82 / 0.78
  • Qts 0.78 / 0.74
  • Cms 0.14 mm/N
  • Mms 304.5 / 306.5 gr
  • Bl 16.3 N/A
  • SPL 93.1 / 93.8 dB
  • VAS 178.0 L
  • SD 1210cm^2
  • Xmax 23mm
  • RMS 950 watts
  • Overall Diameter 18.5"
  • Displacement 0.19 Cu. Ft.
  • Cut out 16.75"
  • Mounting Depth 9.5"
  • Sealed: 4.25-4.75ft^3
  • Ported: 6.5-7.5ft^3 @ 27-34hz w/15.25^2 of port per cube
