Followers
0
Recently Browsing 0 members
Recent Topics
- 7 comments
- 434 views
- 1 comment
- 594 views
- 1 comment
- 214 views
- 3 comments
- 1,083 views
- 8 comments
- 2,005 views
- 1 comment
- 164 views
Similar Content
By TLOTIS
I’m looking to build a ported enclosure for (6) Ampere Audio AA-2.5 6.5” D2 subs. They will be run on a 5k/1 ohm stable amp wired at a 1.33 ohm load. There will be plenty of power as they are 500 rms and 800 max. I can’t seem to get anything from Ampere Audio on the port size I need. With sub displacement my box needs to be 2.48 CF (+) port displacement. Does anyone have suggestions or know how to calculate the port size? Square inch and length is what’s needed. Hopefully someone can help on this
By Ryann627
Thanks in advance guys.
By 121gigawatts
I just bought a zv5 15 thinking it was dual 2 ohm and it’s dual 1 ohm. I have a few questions. First, can it be recone to dual 2? Because I read some motors are only configured to function on the original impedance. Idk. And if I can’t get it recone, can I run that amp at .5 ohm unclipped on that zv5 and not overpower it? Should I run it at 2 ohms? I hope it can be reconed to dual 2. In need of help. Thank u.
Recent YouTube Posts
