BigDaddy13440
Dayton Audio subwoofers
Am currently looking at subwoofers to upgrade from my lowly Powerbass S-10D's. Have been running a Lightning Audio 1001.d monoblock @ 1 ohm for the last year, and every time I get it cranking, the amp shuts off after 10-15 minutes, blowing fuses. I am running a 250 amp alternator, and a brand new 1000ca/800cca battery, with 1/0 run back to my distribution block, and a 14" 4ga run to the amp, with the big 3 under the hood. Will be adding a second battery, under the hood, as there is a second battery tray. I really don't want to run much more power than what I already have, as I don't want to get into having to add a dual alternator, or putting another battery in the back. Probably looking at a1200-1500 watt amp, possibly Skar or Audiopipe, just depends on what I can find for a deal.
The Powerbass subs are only rated at 350 watts rms, I'd like to be able to run a clean 600-750 to each. I haven't found much out there for a sub that has a high sensitivity, other than the Dayton's below. Most 10" subs that can handle 500 watts rms or more only have a sensitivity from 83-87db, these Dayton's are supposedly 90.5db. If I remember correctly, it takes double the power to achieve 3db more in output - if that's so, then these Daytons with 600 watts would have the same output as a different sub pushed by 1200 watts at a 87.5db sensitivity, or 2400 watts pushing a sub with 83.5db sensitivity.
I know that Dayton is primarily a home audio company, but these have me intrigued. Specs look decent, and what other content I've found online seems to agree.
If not these, then make another suggestion for a higher-sensitivity 10" sub, that will work in a 1.25-1.3cu ft enclosure (mine is about 2.8 cubes, less sub and port displacement).
https://www.parts-express.com/dayton-audio-rss265ho-44-10-reference-ho-dvc-subwoofer--295-463
All the specs aren't worth reading like that.  All that being said the HO is a great driver.
And I've been around the forum for long enough to know that your own tastes are not the "slapping, buzzing, tin can farting" noise that most people with multi-thousand watts and 4 or more subwoofers desire. I've had two fifteens in my truck before, I've been in vehicles with eight twelves, and it's not my cup of tea, either. I want, good, tight, accurate bass that doesn't overwhelm the rest of the system. While I'm not the audiophile that you are, I respect your opinion as your taste is probably the closest to my own.
While I occasionally listen to some Eminem, I don't generally listen to rap. My musical interests are generally modern, hard and alternative rock, ranging from Alter Bridge to Velvet Revolver, Alice In Chains to Powerman 5000, Ronnie James Dio to Def Leppard. I'm 47, and grew up in the Hair Metal era.
I am not a bass head, but it is EASY to get me to get a larger diameter driver.  In the 10" domain those are nice, but if you can fit a larger enclosure there can be a win there too.
I'd love to be able to go larger, but my enclosure is built into the back corner of my Yukon XL - doesn't take up any floor space whatsoever.5a5616bdab4ad_Box7.thumb.jpg.3504d97438125b00d0572716b22359a5.jpg5a5616bf361fb_Box6.thumb.jpg.3006ceadb9d81ecf8c22c65720a9a9e9.jpg5a5616be7377a_Box8.thumb.jpg.23b849c4d4deff8b0363b86af54b9d6d.jpg5a5616bcda477_BoxCarpeted.thumb.jpg.aabb696f34cc61a69d423abdcaad2929.jpg
Also did a center console, as my middle bench seat was shot. Tore the seat apart, saved the frame so that I would have good, solid mounting points for the console. Have two older Powerbass S-10s (single coil) in a 1.2 cu ft sealed enclosure, planning on running them with an old Kenwood 250w monoblock for midbass, most likely from 60 Hz to about 120Hz. Want to anchor the front imaging, I did this in my old Tahoe, and really liked the way it sounded.
The base, with all my junk underneath. None of that will be in there, will be mounting two of my amps underneath - that's what the cleats are for, to raise the console itself up.
Front section of the console, sealed enclosure for the two 10's. Not ported, I have those ports sealed off with the "puck" from the cutout, they make great cupholders, can easily hold a 32 oz bottle of Powerade. The one hole was off by about 1/8th of an inch, but anal retentive mind wouldn't deal with it, so I ovaled both holes, and built out the holes a bit with some thick marine-grade tape. Problem solved.
Two tens, wired in parallel for a 2 ohm load.
Console pushed all the way forward, matching the contour of the dash. You can see how it is elevated off the base (still have all my junk in there during the test fitting, since removed and filling up the storage space).
Center console storage, fits tight with the forward enclosure.
A couple of side trim pieces, don't want everything to be square and boxy. The holes in the bottom enclosure are there for two purposes - 1) allow ventilation for the amps, and 2) putting blue LEDs inside, will get a nice glow radiating out onto the front floor.
And finally, the lid for the storage. It flips open towards the passenger seat, there's enough of a lip where it extends over the curved trim piece so that I don't need to build in any handle or finger pull.
I have a roll of the same carpet that I used for the rear enclosure, using that and some darker gray carpet to wrap everything, give it a little bit of contrast.
Wish I had an enclosed garage, I could be working on this while I'm out of work recovering from surgery.
Edited by BigDaddy13440
I absolutely love that center console man, dope ass hell :fing34:
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 469 views
        • 1 comment
        • 680 views
        • 1 comment
        • 234 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,113 views
        • 8 comments
        • 2,040 views
        • 1 comment
        • 193 views
  • Similar Content
    • By BigDaddy13440
      Pretty much as the title implies.... I've got a 2004 Yukon XL, and I'm updating the entire system. Just replaced my alternator with a 253amp model from a 3500 series pickup (factory option! bolted right in!), will shortly be wiring up a second 1000cca battery. Dual 1/0 runs to the rear, fused at both ends. Currently only running (1) amp, and old Lightning Audio 1001.d @ 1 ohm, will be swapping that out, most likely to a Skar RP-1501.D. Two Powerbass S10-d (dual coil) subs in a 2.7-ish cu ft box built into the rear quarter panel. Tuning is way too low, probably about 24-25Hz. Factory speakers in the doors and rear pillars, will soon be changing them out - probably doing a pair of 6.5's in the front doors, a single 6.5 in the rear doors, and a pair of 10" Powerbass S-10's (single coil) sealed in the front portion of my center console as mid-bass, from 60-150Hz. Will plan on running the speakers and front S-10's on a five-channel amp, most likely Skar's AP-600.5.
      I've got nothing set in stone for the 6.5's, there are literally hundreds of options - but if anyone has some reasonably priced option, please offer suggestions. My biggest dilemma is figuring out what to put in the rear C-pillars. The factory fill is a 2" or 2 1/2", only about 3/4" deep. I'd like to go bigger, even if it's a 3 1/2" or 4". Would run them in parallel with the rear door speakers, dropping the load down to 2 ohms, the same as the front doors. Has anyone ever seen the C-pillars upgraded/enlarged? I found a pair of PPI Sedona series 4" two-ways, supposedly will handle 60 watts RMS, max of 200 watts. The Skar 5-channel is rated at 90x4 @ 2 ohms, so each would see a safe 45 watts.
      Thoughts/suggestions?
    • By Tirefryr
      Selling off everything but a few things.  All items are BNIB unless otherwise noted.  I am NOT interested in trades, sorry.
      SOLD!
    • By altoncustomtech
      Okay, this little build will be going into my 1992 Oldsmobile 88.  I bought the car about 7 years ago right after I started working for the pipeline I'm working for now.  I got a hell of a deal on it and got it so that I had a car just for driving to work so my wife would still have the van to drive at home.  I only drove the car for a couple of years before I bought the Jimmy and right after that I gave the Olds to my mother and father in law to drive because their car broke down and my mother in law was having to run around to doctors and things for her cancer treatments and such.  Well fast forward from then and I find myself with the Jimmy out of commission and my father in law wasn't driving the Olds anymore because he had gotten his own car.  So he gave the car back to me so I could have something to drive to work again.
      Just before I gave the car to him to drive I had dropped an OLD Pioneer CD player I had bought used on Ebay for $20 to put in the car because the factory radio didn't work.  I also put a pair of Hifonics Zeus Components I had lying around from another project in the rear deck in place of the bad factory 6x9's.  It still sucked but it made music.  Now after driving the car awhile again I've gotten fed up with the damned thing.  Only one of the mids in the Zeus components are working anymore and the front factory tweeter/mid thing in the front doors are shot.  So I've picked up a little bit of stuff I got for cheap and I'm hopefully going to get it sounding better than it is right now.  I'm also going to use this little build as an experiment as well on some ideas I have floating around in my head.
      The equipment going in:
      Pioneer DEH-X7500HD - Used a discount I had on hand at SonicElectronix to get it for under $80
      Aura 4x6 coax's - On clearance at PE.  I don't normally mess with oval speakers and such but for their clearance price I wanted to try them out.  Going in the front doors.
      Dayton SD215A-88 - Used a promo code here and got them for $19 each.  Going to use the pair as dedicated midbasses in the rear deck.
      JBL GTO1004 - Already have it on hand, will use it's internal crossovers to run the Aura's up out of harms way and utilize the Dayton's in the midbass range.
      We'll see how it turns out.  It should be a fairly quick and easy build.  The goal is simply to get something that sounds reasonably good with better overall response than it has now and able to get more volume out of it than it can produce now, especially without the front speakers sounding like they're going to puke on every drum hit even at low listening levels.
  • Recent YouTube Posts
