onebadmonte
Horns Bazookas & SI DS4 18 SQ FTW!
And now for a little bottom end brought to you via a Stereo Integrity DS4 18.
Freshly cut wood.
I'm using a textured piece of abs plastic one the baffle for a little something extra.
Box with a pair of Bazooka MGA1100h strapped (2KW) to the 18. Boom!
Bazooka 4 channel, Arc PS8 and Stinger wire goodies.
A little carpeting action.
Finished product.
Pics for those that gotta have moar!
http://s1005.photobucket.com/user/onebadmonte32/Suburban V3/Sub Box/story
Thanks for looking.
Got me a little something extra for the PS8.
Drew me up a little housing to mount in the dash.
Laser cut FTW!
Formed and welded.
Cut some mounting ears and welded some flanged nuts using works tig.
Used my crappy flux core mig at home to eff everything up. :(
The final install
For more behind the scenes pics:
http://s1005.photobucket.com/user/onebadmonte32/Suburban V3/PS8 Pod/story
Thanks for looking. :)
Absolutely fantastic!!
So how's the tuning going?  Are you liking the PS8?
Welcome back my friend. Nice Ride !!!
Nice work as always!  Now TUNE :)
:droolcup:
I want to know how it sounds, glad to see you back here.
Thanks. Tuning is slow going. Part of it is making sure I get good measurements. Then tackling the EQing and making sure it does whats intended. Definitely and art for sure.  I'm digging the PS8. I bought it second hand for a good deal, that's why I went with it. I wish it had shelf filters and all pass filters, since that's all the rage now in the ESSQUE circles. :D For now it gets the job done. Thanks for stopping by.
8 hours ago, Infinite913 said:
Love it all. Welcome back monte.
Awesome. Glad to start posting again. It's been a long while.
Thanks and thanks. :)
I appreciate, thanks. Definitely gonna get to tuning.
17 minutes ago, jcarter1885 said:
:droolcup:
Ha ha. It's sounding good. Still needs work, but it's getting there. Glad to be back. :)
At this point everything is up and running. Horns are highpassed at 1600hz 24db/oct LR. The mids are playing 80hz to 1600hz 24db/oct LR at both ends. Subs are lowpassed at 80hz 24db/oct LR, no subsonic filter. The highs are non-existant with out some eq. A buddy recommended a special filter Veritas used to offer for the horns they once sold. Here is the info I was given.
This the specifics on the filter.
This is the modeled response of the filter by my buddy.
Here I go trying to calculate the input impedance of the Bazooka amp.
After using this calculator I came up with 10k input impedance. Close enough. :P
Screenshot_2016-07-31-20-19-37-1_zpsjqpw
Here are my little filters.
This was the response of the horns before the filter. Left black right red.
HORNS%2007192016%20VOL30%206TH%20OCT_zps
This is the response of the horns after the filter was installed.
HORNS%2009182016%20VOL30%20ONE%206TH%20O
On to more tuning. :)
Things happen. Sadly one of the channels on my little Bazooka 4 channel started cutting out. I had to swap it out for another amp I had laying around, JL HD600/4. :D
Before with the Bazooka
After with the JL amp
Luckily the input impedance is the same on both amps so no change to the horn filter thingie. I did have to reset the gains on the amps and the PS8. The JL has a small range and low voltage requirement for the low level inputs so I had the lower the signal at the PS8 since the Sony has 5V pre outs. :/ Back to tuning. :D
At this point in time Stereo Integrity discontinues the DS4 line and closes them out at a I can resist price. I pick one for just in case. :) Unfortunately storage space has become a preminum and I say eff it, I can cut another hole in the box and run two. So much for the no upgrades. :P
Moar sub pics.
Everything back out.
Fingers crossed that I don't eff it up. :D
Now its a box for two.
All back in.
The subs are dual 2 ohm coils. The amps put out 1k at 2ohms or 750w at 1ohm. So I take a hit in the power dept but gain in the cone area side. All in all its a wash. :D I need to start tuning.
Goodness its a rebuild during a rebuild while doing the initial build. Keep it coming.
Bad ass install, great work man!
Ha ha, sorta. This build is what I've been working on for a while. The build log is playing catch up. :)
Thanks. :)
At this point the build is current and up to date and ready for the 1st tuning session. Up first is an impedance sweep of all the drivers in their installed enviroment.
The driver side horn
The passenger side horn
The driver side woofer
The passenger side woofer
Lastly the subs
Now that we know what to expect here is the baseline measurement.
Red = Right/Passenger Side
Black = Left/Driver Side
SUBURBAN%20BASELINE%20MEAS%201_zpsvns9xe
Wow, well with that said, here is what I went with PEQ wise on the PS8
PS8%20GEQ%20FINAL%20TUNE%20SESSION%201_z
This is was the final measurement looks like.
SUBURBAN%20FINAL%20TUNE%20SESSION%201_zp
So far so good, but needs more tuning. :)
Very nice setup Brother.
Specifics are nice, but in all, it's all about the human ear.
Wish I could hear it !!!
Thanks. I'm gonna be at the Aggieland show @College Station the first weekend this June. Big SQ show if your into that stuff. :)
