Water resistance demo and heat reflection demo of our newest product line of Hydrophobic Melamine Foam and Hydrophobic Melamine Heat Shield
Find them here https://store.secondskinaudio.com/
Amazing!
20 hours ago, ///M5 said:
What temp does it melt at?
MegaZorbe Hydrophobic Melamine Foam Temperature Range: -300°F to +356°F, intermittent to +400°F
The Heat Shield on the MegaBlock Hydrophobic Melamine Foam Temperature Range: -40°F to +1,000°F ** Upper temperature limit is reliant upon a finished part being larger than the surface area exposed to 1000°F and a minimum of 1” space between the heat shield and the heat source
The high temp adhesive backing Temperature Range: -40°F to +450°F
The MegaBlock Hydrophobic Melamine Heat Shield was designed specifically for our aerospace and military clients that have used our Thermal Block for the past 17 years, that is why the heat rating needed to be so high, as a vehicle would never reach temps even half that high.
All specs and testing results are posted on the product pages.
www.secondskinaudio.com
And yes that says 1,000 Degrees for the Heat Shield, that is not a miss print ;-)
Second Skin For The Win!!!
Nice thank you.  May need some of that for something non-automotive deadening related :)
Don't forget to check out the Velocity channel in March/April to see this amazing product being used on our huge West Coast Customs build!!!!
Ken getting mic'd up for the video shoot with Damplifier Pro, Luxury Liner Pro, and MegaBlock Hydrophobic Melamine Foam for our build on West Coast Customs.
15977198_1523596454318009_71438618708979
