Adrian_D
DIY circle jig
just part of it. more (pics) to come friday/saturday
the pin will attach to the bottom of the T. the C-shaped part will attach to the router. T part connects to the router with 2 metal rods. i can move the center of the circle right next to the bit. no more troubles with tweeter holes :woot:
ideas for a good pin ?
skil circle jig (pin goes in one of the 2 holes):
only useful for big circles. smallest diameter ~8 inches. also, the pin isn't very stable :(
I have a few homemade ones, but all out of cheap flat board.
HMMM never seen one before
<<<NEWB
and it looks hella usefull.
J
I too have a homemade one - out of masonite. Similar to the Jasper. Wish I could use the Jasper but my router won't fit it...
For a pin you can snag one of those metal pins you see in cheap tv/stereo cabinets. Home Depot sells them in the nail/screw/misc section.
Got a dull drill bit you don't use anymore ? Could always use it . That's what I use on the homemade jig I have . Works quite well . :)
no Home Depot in Romania :P
but there is something similar. and it's a 15 mins walk from my house. i'll see what i can find tomorrow. hope to finish it. i still need some VERY short wood screws to attach the metal rods to the T part and some normal screws for the other part of the jig...
That would work.
It's how us old bass heads use to cut perfect circles before the days of the jaspers . :D
I just used.............well a jigsaw..............drill a decent hole in the middle and jig it out.............the I discovered some contraption that some people call a a "router". I think its Latin.........Either way it cuts cirles rather well. More accuratly and more proper.
J
i have quite a few dull drill bits.
screws were too long. i had to grind them off. angle grinder action ftw :)
pin and bottom of the T-part. Ramos, thanks a million for the idea.
how it attaches to the router :
smallest radius :
biggest radius :
i was lucky 2 screws fit. i fuxored the pattern because i rushed :(
it's very stable compared to the "stock" jig. no worries about adjusting the radius. i guess i achieved my goals of stability and wide-range radiuses.
price tag : less than .5$
if this jig self-destructs, i'm going to build the next one out of some stiff plastic.
That's a pretty good way to get the smaller radius'.
Hell, even a new one I just use what is close by.
I to have a home made on ...its a tape measure with 3 holes in it
1 hole at the 1 inch mark
1 hole at the 8 inch mark (for 15 inch subs)
1 hole at the 6 1/2 inch mark (for 12 inch subs)
Put a nail in the hole at the 1 inch mark, pull out tape to what hole u want to cut, place sharpie in that hole and spin around!! works perfect.
i can't imagine how to attach a router to a tape measure. and i also need to cut holes for tweeters and mids. not just subs.
This is not for a router, This works with a jigsaw. This will also work for tweeters ...just make another hole for the pen/marker, or try another method. Like I said this is my method I use
I'm to the point now , that I use an 1/8" bit with the jasper instead of the pin . It seems to fit a little snugger . :)
