afearlesshunter
2001 Civic SDA3 12's 8k
11 hours ago, ///M5 said:
I thought I understood, but you used the terms so interchangeably I wasn't positive the OP followed.  It also isn't the first thing you should do.  Somewhat of a bandaid and one with minor benefits.
Reason being is that the biggest difference in a bigger pulley is that it will increase the tension on a fixed length system.  With a tensioner of course it shouldn't change or only minimally based on the spring constant of the device.
As for surface area that the belt adds.  In a perfectly simple world (ie only two pulleys so maximum pulley contact) you would only gain the amount (1/2 circumference of big pulley - 1/2 circumference of smaller pulley).  Which would mean going from a 4" to a 4.5" pulley you would gain less than .75" of contact along the length of the belt.  If the angle of incidence is such that it normally only touches 25% of the pulley (more normal) you can cut that number in half.  The 6-12% contact patch gain while significant is probably less effective than a clean new pulley and non-glazed belt.
Just replacing things isn't the approach I'd take.  Making sure everything is setup right is the first step.  Most people are lazy and skip this.  Don't.
Says a pulley and non glazed belt is his best bet, then in the next sentence says replacing things wouldn't be his approach. Your tactics confuse me! And who cares about contact patch, that's not the problem. The problem is he needs a larger pulley so the alternator is easier to turn and this isn't going to change much except the alternator will actually be turning instead of just setting there while a belt slips over it. But like I already said a wider pulley and a good belt like the Goodyear above wound be his best bet, then if it's still slipping then his only other choice would be to go to a slightly bigger pulley. But deffinetly try a wider racing belt if you don't mind the expense.
Edited by Billy Jack
10 hours ago, edouble101 said:
I had a similar issue with my aftermarket alternator. Your belt squeal is caused from the smaller diameter aftermarket alternator pulley. The only way I was able to overcome this was with a 0.3" smaller OD diameter belt along with a better belt. The belt that I used was a Goodyear Gatorback.
Another option is to use an idler pulley on the bottom bolt on your alternator mount. This will drastically increase belt wrap around the alternator pulley. I did this on a previous vehicle I had.
Not a good pic of belt wrap but the difference was significant.
I you use a larger pulley you might as well put your stock alternator back on.
I ordered a gator back thats .5" shorter than the one I have on, so hopefully that does it. I do like the idle pulley on the mount though, Ill have to keep that in mind. Thanks for sharing that, never really thought of it.
Part of the problem is a longer than stock belt is needed to fit onto the pulley. The alt is a much larger case and swings a bit further away from the system in order to fit the bracket on the engine.  Has to be long enough to even get the belt on at all, but at the same time short enough to keep it from slipping.
Edited by afearlesshunter
Now the iderly pulley does sound like a good idea never tried that before.
UPDATE: The good. New gatorback belt is on and no slipping. Woot! Pac lc-1 around halfway and holding 14+ easy while driving.
The bad. I need to get the SDA3's into different boxes. Excursion limit is reached super fast between 34 and 38hz. Thinking of going down to 4 cubes tuned to 32 single chamber, probably using an 8 inch aero. Not sure if I should pursue the trunk wall still or go with something different such as port side subs forward or back. Maybe just subs rear with port rear aswell.
More power smaller enclosure...in my testing experience. With the increase in voltage & amperage you amp with be able to deliver a more constant amount of quality power
Thats what Im thinking. Although, I can't get winsd to show the excursion that Im getting currently. With 4k input into each, its only showing just under 23 mm of excursion yet I keep having problems with what sounds to me like bottoming out.
Alrighty, about to get back on this build. Starting hopefully this weekend. New enclosure should be 3.76-3.9 net depending on port length I end up at. One box this time, common chamber. Starting orientation will be subs firing forward, port to the drivers side. Ill test drivers back as well.
Box outside dimensions frame. worth the $3 to see if the stupid thing will fit.
Audible Engineering adjustable port.
And finally have some answers and more questions on the noises that seems like bottoming out in the previous enclosures. I have been testing the drivers free air and have found that the cone hits the leads. I haven't made an exact measurement but I do not believe this driver will ever be able to reach xmax (stated to be 29mm) due to the leads being so close. :Doh: I have not yet brought this up to the company but I will be shortly after I measure the distance of actual travel. Kinda sucks because it happens WAY before mechanical bottom and it is very loud in the enclosure.
A linky for the vid of the leads.... they're close af.
Sucks about the sub, i know how annoying tinsel slap can be.
Poor woofer design...
Yep, I might as well have some pa subs with this amount of throw.
Pretty tasty other than this. But yep I feel that neither damien or the build house really tested the smaller woofers. All I ever saw decent testing on were the 15's and 18's. I can't imagine the 10" version.
I've got an original JBL 1500GTi if you want an upgrade.  Hasn't been used since 94.
Just spoke with Damien. I measured 5/8" ~ 15-16 mm from cone to lead. He said to start with bending them outwards towards the basket spokes more and maybe outward a  little. He's said he'll be sending the pics and measurements to nick at IA to make sure the rest are gucci.
Lol thanks but don't need more drivers until I get rid of some, nearing 15 atm and most don't get used.
    1. Recent Topics
        • 7 comments
        • 328 views
        • 1 comment
        • 398 views
        • 1 comment
        • 161 views
        • 1 comment
        • 147 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,006 views
        • 8 comments
        • 1,918 views
  • Similar Content
    • By Second Skin
      Duster Joe's 1976 Plymouth Duster Trunk Build
      Customer Joe M. Build Info:
      1976 Plymouth Duster 2006 6.1L Hemi 1996 Borg Warner T56 (Viper) Trunk is 53 cu/ft space
      Complete car was done with three boxes of Damplifier Pro (90 sqft total). Trunk specially was completed using 8-10 sheets of Damplifier Pro.
      The trunk before any Damplifier Pro sound deadening.
      Installing the Damplifier Pro butyl sheets.
      Interior trunk walls only needed one full sheet of Damplifier Pro each to reduce sound to just a deep thump.
      After the Second Skin Damplifier Pro was installed. The Damplifier Pro dropped the sound of the fuel pump to nearly no sound at all.
      Here a picture showing the trunk sound deadening completed. It’s totally covering the floor, wheel wells and one full sheet of Damplifier Pro on each inner quarter panel.  The rear trunk panel was completely done as well.
    • By mikebingham34
      Hey everyone,
      First off I wanna apologize for changing my mind so much. My financial situation has changed, so my future setup ideas have too. Even though I have not followed through with other plans ya'll have helped me with, I have learned a lot for each comment or post I read.
      On to the enclosure idea. I will be getting a single SA-10 D2 as soon as my current setup sells. I will be running it off of a BRZ1200 @ 1 Ohm (for headroom). My goals are for it to be decently loud (I have had an E-12, hope to be comparable to that), and flat sounding for all music types... From dubstep to decaf to classic rock to country. It will be in my daily which is the trunk of a 2000 Honda Civic Sedan (DX EJ6, D16Y7 Auto). I am planning on building an enclosure that is 1.4 cubic feet, with a 17" long, 4" aeroport, tuned to 34.8 Hz.
      My questions are as follows:
      Is the box too large? I commonly see Jacob recommending 1-1.25 cubes for a ported SA-10.
      Should I keep the 4" aero? It gives 9" of port per cube (high end of the spectrum for an aero)
      Or go with a 3", or just go slot port... If I go slot, what kind of port area should I use?
      Lastly, is that a good tuning? I would like an F3 around 28Hz.
      Thank you for all your help, as always.
    • By grayta
      This topic is really for my new upcoming build which will be two Sundown Audio SA-12s on a Hifonics BRX 2400.1D sealed off from the trunk.  The box is currently being built by Dave The Box Guy, it will have three different tunings with interchangeable ports (20Hz/28Hz/45Hz).  For now, while I sit and wait, I am going to post my current set up just to show you all some of the work I have done so far.   I don't have all the pictures since some things were done a little while ago such as, deadening, changing my door speakers, wiring etc. but I will eventually tear some things off and show you how I installed everything.  Here it is....
      Current build:
      Head unit: Kenwood KDC-X995 w/ iPad Mini
      Equalizer: Clarion EQS746
      Mids/Highs: 4 Infinity Kappa 62.9I (wanted to keep stock look so they are in the stock location of the doors)
      Subwoofer:  1 15" Sundown Zv3 D2
      3.3ft3 enclosure tuned to 33hz (Sub Up, Port to the side)
      Mids/Highs amp:  Hifonics Zeus ZXi80.4
      Subwoofer amp:  Hifonics Brutus BRX 2400.1D
      Electrical:  Stock 150A alternator, XS Power D6500, BIG 3 to come soon
      Deadener:  Second Skin Damplifier
      ***The only thing that will change with the new build will be the sub stage which is listed in the first paragraph, everything will most likely stay the same... for now lol***
      This isn't my actual car, but this is what it looks like completely stock on the outside..
      Here are some pictures of my car after some cheap mods!  Tint is %30 and hubcaps plasti-dipped!
      Tinting my tail lights soon!  Don't have a pic before the de-badge so here is the after..  If you can tell I replaced the stock antenna with a "shorty"
      On to XS POWER, haven't done the BIG 3 yet but that is on the list of things to do.. Here is the stock battery under the hood.  I already ran the 1/0 gauge wire through and plan on shortening the wire to the fuse soon as well.  I will try and get pics of how I ran it later..
      Look how small the stock battery is compared to the XS Power D6500!!
      Finally installed, it was a b**** to get into that small space.
    • By mikebingham34
      So I will be ordering an OA-12v2 D4 very soon after selling my current system (Upgrading from a Fosgate Punch P2 12, 2011 model). I have a Rockford Prime P500-1d to work with, so the sub will see just over 500 watts. I have read in many places that the more power, the smaller that the box can be, and the less power, the larger you can build the box... generally. So I was thinking of doing a 2.5 cuft enclosure for the OA, on the 500w. It will be going in the trunk of my 2000 Civic sedan, most likely sub back, port side. Does this sound appropriate? Is there another way I should approach this? The box will be tuned to 30Hz via 4" aeroport. Thank you for any help, and I apologize if I left out any important details.
  • Recent YouTube Posts
