afearlesshunter
2001 Civic SDA3 12's 8k
Round number two for the real deal. Started planning and collecting for this build a few months after I got the car, so basically a full year now. Don't really have an idea for goals yet, I hope its loud and I will get it metered in the spring. Super close to tearing into it and getting it done, waiting on a few more things to arrive in the mail.
2001 Honda Civic Sedan ES1
Singer 320A
Soundrive SDA3 12's
Taramp's HD8000 Ex
PPI 900.4
Xs Power D5100 & 3100 (maybe more battery coming)
4/0 welding cable
SHCA Fuse Holders / Speaker Wire / Battery Terminals
Kenwood X399 HU
*Possibly going with SSA Evil 6.5 for mids, no clue on tweeters yet*
Lots of misc stuff to make it all happen.... on to the pictures.
The car
Box design, 2.3 ft 30hz
In the trunk. I will be make a front panel for it and completely sealing off once I finish wiring in batteries etc.
Still waiting on my 16 ton crimper, triple 4/0 inputs, probably get some quad 8 awg for the speaker terminals whenever they are back in stock. Still need a shorter belt for the alt and just small stuff to wrap it up. Advice etc always appreciated. Thanks for stoppin in for a gander!
Edited by afearlesshunter
I think those SDA subs are going to be great.
Alrighty, got my hydraulic crimper in the mail but haven't tested it yet. Started tearing out the rear tonight and trying to figure out how to fit group 31's within 1/16" height clearance, probably have to do a cut out of the new floor piece where they are.
Pulling enclosure ( everything for this build is made to be relatively easy to remove.)
Ideal location for first batt
Stopped here for the night, still need to pull all carpet from trunk, rear seats, passenger seat etc.
Tuned in for more.
I'm curious about those Soundrive subs : you will have them on a 8000 watts amp ? Those subs must be strong.
Nice. I'm tuned in.
Wish I had time to work on my ride.
I got a buddy here with 2 soundrive 15s v1 in a no wall setup jeep commander and it is on soundigital 8k and they love every bit of it. He is tuned 36hz
8 hours ago, Notorious97200 said:
Tuned in for more.
Yeah its a Taramps for whatever thats worth. I expect to have rise and am only wiring at 1 ohm so that 8k will quickly be <4k.
7 hours ago, Randal Johnson said:
Nice. I'm tuned in.
Thanks, I've been waiting for some time for about two months now. The build is probably one of my favorite parts.
Everyone that I've seen and talked to with the soundrive's has been happy with them. Im currently tuned to 30 but might bump up the port area and raise tuning to 32 or so, currently without being sealed up they were getting down well to about 25hz.
More updates hopefully later tonight. Thanks guys.
Finally got the firewall drilled out. Ended up having to use a step bit, wanted to die the entire time. Have two power and two ground from front to rear now. Really hoping to get everything in for a test run before the end of the week, will be working on making everything look nice afterwards.
Lumpy carpet is cool I suppose.
And knu konceptz 4 awg vs 4/0 welding cable just for fun.
Holy cats, cant believe you got 4 runs of 1/0 through the firewall!
Tuned in.
Don't know if you mistyped but... its 4/0 ;)
52 minutes ago, Aaron Clinton said:
Tuned in.
Thanks sir! Hopefully it will go well and maybe playable this weekend.
holy! ;.... dayum!
Got a little more work done last night. Power and ground lugs on in the front.
SounDrive rca's
Aight, got everything in and tested. PPI has been kind of odd for some reason but I'm moving it out of the trunk soon. Wanted to die wiring up that rear batt with 4/0 after the enclosures were in. They had to be in for amp wire measurements.
First day had problems with one sub unloading much faster than the other, checked and rewired seems fine now. Need to go back to advance and get yet another belt thats a different size , slips like a mf'r below 1500 rpm, 40" is like barely too long and Im pretty sure the alt is swiveled out all of the way, 39.76" will be the next test size.
The amp is surprisingly efficient. No clue how much power I'm getting from it. Gain was set with 50hz sine wave -3dB with subs unhooked, set right before clip light even starts in. Honestly, I haven't turned the lc1 past 1/2 way ( gain was set with it all of the way up). Im still making sure the subs are a little broken in (if you believe in that). Im always looking back at them and listening hard to make sure they don't bottom out but its really hard to tell with the doors and deck flapping around.
Not many pics for now. Im honestly embarrassed to show it in its current state. The boxes have no front beauty panel, I haven't made a new trunk floor yet so both boxes are crooked and dip down at the center where they come together. Wiring looks like sht. No rack for the 8k yet so its got foam on the bottom and back and held in place with a sheet of mdf.
Door holes cut to fit 6.5's
Amp turn on stuff and Xs 31 (that's too deep for the spare tire well :Doh:
Under the hood was extremely tight, but didn't turn out too bad.
Little Update: PPI 900.4 seems to be doing fine but still am going to move it to the interior. Alt belt continues to slip even at 2k rpm with anything past halfway on the lc1, Ill be ordering a continental elite 39.5" soon hopefully to get it a little tighter. From about 35hz and up I can not tell but and getting concerned for the subs, might be bottoming out but Its hard to tell when I have to keep my foot on the throttle for the belt not to slip at that level. I can smell them slightly after a few minutes but the cones/ dustcaps don't get that warm, Ive had others much much warmer.
Received my quad 8awg speaker posts the other day, waiting on more lugs to arrive to get those on.
I think no one will ever know as there always sold out lol. Kind of like Crescendo sold out for over a year.
Damien has another batch cooking up along with work being done on some new stuff like 4 inch coil and maybe neo motors too for a 3 inch.
You need a bigger pulley and belt as tighter want do a thing but make the belt fail quicker. I have seen this very problem a bunch of times and everything was tried and didn't work until they got a larger pulley. And I already know what everyone is gonna say, (but it want turn as fast causing it to not put out as much), trust me a alternator actually turning with a proper size pulley will do far more then one that's just setting there with the belt spinning on it. Besides it's really not that much difference anyways.
Im willing to try a few more belt sizes before I pull the alt out because that requires the removal of almost everything on the drivers side of the engine. Also, a larger pulley would not greatly increase the surface contact that the belt makes or make the belt much tighter and may lead to having essentially no output at idle.
Just remember when you finally realize that you have tried everything to no avail, and are changing pulleys anyways I tried to give you good advise from years of dealing with the same problem. And do you honestly believe a alternator that's not turning much because the belt is slipping, is gonna put out more then a alt that's turning to 90% capacity? Trust me bud I'm trying to save you a lot of trouble. But I will say, if this isn't a new belt or you haven't switched to a wider pulley then yea I would try that first. But if you have already done all this and your tentioner is good then save yourself a headache and go big. This is a common problem with high output alts and bigger pulleys is the only thing I have seen work.
Bigger, larger, and wider were all used in your description....hmm.  Wider is obviously the ultimate choice, but at what cost?
What are you on about now? Obviously I was talking about a taller pulley with a greater circumference in my first comment, and I only mentioned wider in the second. He understood what I was saying. Some of us have enough common sense to process what other are telling us.
I thought I understood, but you used the terms so interchangeably I wasn't positive the OP followed.  It also isn't the first thing you should do.  Somewhat of a bandaid and one with minor benefits.
Reason being is that the biggest difference in a bigger pulley is that it will increase the tension on a fixed length system.  With a tensioner of course it shouldn't change or only minimally based on the spring constant of the device.
As for surface area that the belt adds.  In a perfectly simple world (ie only two pulleys so maximum pulley contact) you would only gain the amount (1/2 circumference of big pulley - 1/2 circumference of smaller pulley).  Which would mean going from a 4" to a 4.5" pulley you would gain less than .75" of contact along the length of the belt.  If the angle of incidence is such that it normally only touches 25% of the pulley (more normal) you can cut that number in half.  The 6-12% contact patch gain while significant is probably less effective than a clean new pulley and non-glazed belt.
Just replacing things isn't the approach I'd take.  Making sure everything is setup right is the first step.  Most people are lazy and skip this.  Don't.
Please read M5's signature, then read it again.
    1. Recent Topics
        • 1 comment
        • 89 views
        • 1 comment
        • 59 views
        • 1 comment
        • 58 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 911 views
        • 8 comments
        • 1,837 views
        • 1 comment
        • 97 views
  • Similar Content
    • By Second Skin
      Duster Joe's 1976 Plymouth Duster Trunk Build
      Customer Joe M. Build Info:
      1976 Plymouth Duster 2006 6.1L Hemi 1996 Borg Warner T56 (Viper) Trunk is 53 cu/ft space
      Complete car was done with three boxes of Damplifier Pro (90 sqft total). Trunk specially was completed using 8-10 sheets of Damplifier Pro.
      The trunk before any Damplifier Pro sound deadening.
      Installing the Damplifier Pro butyl sheets.
      Interior trunk walls only needed one full sheet of Damplifier Pro each to reduce sound to just a deep thump.
      After the Second Skin Damplifier Pro was installed. The Damplifier Pro dropped the sound of the fuel pump to nearly no sound at all.
      Here a picture showing the trunk sound deadening completed. It’s totally covering the floor, wheel wells and one full sheet of Damplifier Pro on each inner quarter panel.  The rear trunk panel was completely done as well.
    • By mikebingham34
      Hey everyone,
      First off I wanna apologize for changing my mind so much. My financial situation has changed, so my future setup ideas have too. Even though I have not followed through with other plans ya'll have helped me with, I have learned a lot for each comment or post I read.
      On to the enclosure idea. I will be getting a single SA-10 D2 as soon as my current setup sells. I will be running it off of a BRZ1200 @ 1 Ohm (for headroom). My goals are for it to be decently loud (I have had an E-12, hope to be comparable to that), and flat sounding for all music types... From dubstep to decaf to classic rock to country. It will be in my daily which is the trunk of a 2000 Honda Civic Sedan (DX EJ6, D16Y7 Auto). I am planning on building an enclosure that is 1.4 cubic feet, with a 17" long, 4" aeroport, tuned to 34.8 Hz.
      My questions are as follows:
      Is the box too large? I commonly see Jacob recommending 1-1.25 cubes for a ported SA-10.
      Should I keep the 4" aero? It gives 9" of port per cube (high end of the spectrum for an aero)
      Or go with a 3", or just go slot port... If I go slot, what kind of port area should I use?
      Lastly, is that a good tuning? I would like an F3 around 28Hz.
      Thank you for all your help, as always.
    • By grayta
      This topic is really for my new upcoming build which will be two Sundown Audio SA-12s on a Hifonics BRX 2400.1D sealed off from the trunk.  The box is currently being built by Dave The Box Guy, it will have three different tunings with interchangeable ports (20Hz/28Hz/45Hz).  For now, while I sit and wait, I am going to post my current set up just to show you all some of the work I have done so far.   I don't have all the pictures since some things were done a little while ago such as, deadening, changing my door speakers, wiring etc. but I will eventually tear some things off and show you how I installed everything.  Here it is....
      Current build:
      Head unit: Kenwood KDC-X995 w/ iPad Mini
      Equalizer: Clarion EQS746
      Mids/Highs: 4 Infinity Kappa 62.9I (wanted to keep stock look so they are in the stock location of the doors)
      Subwoofer:  1 15" Sundown Zv3 D2
      3.3ft3 enclosure tuned to 33hz (Sub Up, Port to the side)
      Mids/Highs amp:  Hifonics Zeus ZXi80.4
      Subwoofer amp:  Hifonics Brutus BRX 2400.1D
      Electrical:  Stock 150A alternator, XS Power D6500, BIG 3 to come soon
      Deadener:  Second Skin Damplifier
      ***The only thing that will change with the new build will be the sub stage which is listed in the first paragraph, everything will most likely stay the same... for now lol***
      This isn't my actual car, but this is what it looks like completely stock on the outside..
      Here are some pictures of my car after some cheap mods!  Tint is %30 and hubcaps plasti-dipped!
      Tinting my tail lights soon!  Don't have a pic before the de-badge so here is the after..  If you can tell I replaced the stock antenna with a "shorty"
      On to XS POWER, haven't done the BIG 3 yet but that is on the list of things to do.. Here is the stock battery under the hood.  I already ran the 1/0 gauge wire through and plan on shortening the wire to the fuse soon as well.  I will try and get pics of how I ran it later..
      Look how small the stock battery is compared to the XS Power D6500!!
      Finally installed, it was a b**** to get into that small space.
    • By mikebingham34
      So I will be ordering an OA-12v2 D4 very soon after selling my current system (Upgrading from a Fosgate Punch P2 12, 2011 model). I have a Rockford Prime P500-1d to work with, so the sub will see just over 500 watts. I have read in many places that the more power, the smaller that the box can be, and the less power, the larger you can build the box... generally. So I was thinking of doing a 2.5 cuft enclosure for the OA, on the 500w. It will be going in the trunk of my 2000 Civic sedan, most likely sub back, port side. Does this sound appropriate? Is there another way I should approach this? The box will be tuned to 30Hz via 4" aeroport. Thank you for any help, and I apologize if I left out any important details.
  • Recent YouTube Posts
