mpimm
High Excursion Drivers
Just curious if we are anywhere near seeing this driver, and if so, do you have any information about them?
In my latest shipment I received two 'next-gen' 18" protos. The build quality on them is very good, and should make a few folks happy. The Xmax is 27mm but the T/S specs on them are a bit shy of my target, so I am not going to post them here until I speak to the OEM. Here are some shots:
Best,
Mark
Nice to see an integrated gasket on the fron as opposed to the normal rubber trim ring. Would be nice to see a rubber or synthetic here also, but with budget in mind, the paper/cork/foam does the job at less cost. I wish more manufacturers would integrate this.
'tis looking nice. and omg xmax :lol:
coil options ? power handling ? wieght ? estimate cost ?
I must say, the basket and motor look very nice on that thing.
Can't say I'm a fan of those foam surrounds though.
CAn't wait for a head to head against the MJ.
I'm looking forward to seeing how this things compare to the MJ-18.
Car or HT oriented?
and of course...
PRICE?!?
WOW! That thing looks like its got a 12" mounting depth. Impressive though.
Hey mark.....do a sonotube enclosure with 4 of those for your house...LOL.
Edited by Puggsley456
Ah hell, should I wait for these instead of doing 4 MJ18s? When are these coming out???
thats the same thing im wondering. If these new 18's are cheap enough i would get 4 of them for my astro.
Just firming up some numbers with the OEM. I should have an answer from them by the end of next week.
$150 range?
i call dibbs on the first proto to be sold. i have a sweet idea for a HT setup and an 18" is perfect, plus i want to try M5A, plus i always wanted a proto
Looking forward to seeing what the T/S parameters are for this driver. Hopefully it will model well for home theater. 2 of these would be awesome!!!!!!!!!!!
*** Update ***
Yes. Just got the confirmed numbers. Here you go, along with a low-res shot. It will be called IXL-18.4:
Fs = 15.4Hz
Re = 3.2Ohm
Qms = 4.87
Qes = 0.39
Qts = 0.36
Vas = 556L
Sd = 1029.2cm
BL = 15.1
Mms = 228g
Cms = 0.37mm
SPL = 89.2
There will also be smaller models using the same bottomless motor.
Best,
Mark
does the .4 at the end mean it will be a SVC 4 ohm? If so, are you sonsidering DVC 4 ohm? thatd be nice for car audio, if this woofer will be suitable for it. It looks awesome though :)
Edited by espguitarist91
