jacka
md2 turn on pop
I'm getting sort of a loud bass note when the amplifier turns on and I was wondering what could be the problem. It was a drop in install since I had an amp installed before this already and there was no loud turn ons with the other amplifier. Also, since I put the MD2 in, I'm getting a lot of noise through my speakers at low volumes. The noises go along with how my engine works (i speed up, noise pitch gets higher). The grounds are the same as I had before and I never had this problem, so does anyone know how to fix this or the loud turn on?
thanks eldorado, i just got a reply from greg from us amps too and he said to ground my rca's to the radio chassis and it should fix both problems. i'll try that first.
well im pretty sure it should fix the noise coming from my speakers right? i will probably add a relay if it doesnt fix the turn on.
