Recently Browsing 0 members
Recent Topics
- 7 comments
- 469 views
- 1 comment
- 680 views
- 1 comment
- 234 views
- 3 comments
- 1,113 views
- 8 comments
- 2,040 views
- 1 comment
- 193 views
Similar Content
By jcarter1885
Deadener should be here Friday. I doubt I'll get any work done since there is a car show in town this weekend but I want to do something. I will mount DSP and try to get the ground side of the Big 3 done sometime this week.
By Joshdashef
Hello and welcome to my daily headaches! I'll start this build log off with my past setup, my current, and finally update throughout December as I work on probably the furthest this little Civic will let me go.
My instagram: https://www.instagram.com/joshdashef1/
The Past Build:
Head unit: Pioneer 80 PRS
Mono Amp: Rockford Fosgate Prime 750.1
Subwoofers: Rockford Fosgate P3D4 12" (two)
Kicker 4 gauge amp kit OFC
Stock Electrical (alternator included)
Did do the big three sometime between here and current build
Prefab Box: Q-Power Box (Dual 12s)
Tips: Tesa taping RCA's, Marking RCA's Low/Mid/High or similar,
Big Three with loom. Wire was Sky High 1/0 OFC with some 1/2" loom I believe. Old military style terminals (DO NOT USE THESE) they cracked my battery eventually.
By BigDaddy13440
Am currently looking at subwoofers to upgrade from my lowly Powerbass S-10D's. Have been running a Lightning Audio 1001.d monoblock @ 1 ohm for the last year, and every time I get it cranking, the amp shuts off after 10-15 minutes, blowing fuses. I am running a 250 amp alternator, and a brand new 1000ca/800cca battery, with 1/0 run back to my distribution block, and a 14" 4ga run to the amp, with the big 3 under the hood. Will be adding a second battery, under the hood, as there is a second battery tray. I really don't want to run much more power than what I already have, as I don't want to get into having to add a dual alternator, or putting another battery in the back. Probably looking at a1200-1500 watt amp, possibly Skar or Audiopipe, just depends on what I can find for a deal.
The Powerbass subs are only rated at 350 watts rms, I'd like to be able to run a clean 600-750 to each. I haven't found much out there for a sub that has a high sensitivity, other than the Dayton's below. Most 10" subs that can handle 500 watts rms or more only have a sensitivity from 83-87db, these Dayton's are supposedly 90.5db. If I remember correctly, it takes double the power to achieve 3db more in output - if that's so, then these Daytons with 600 watts would have the same output as a different sub pushed by 1200 watts at a 87.5db sensitivity, or 2400 watts pushing a sub with 83.5db sensitivity.
I know that Dayton is primarily a home audio company, but these have me intrigued. Specs look decent, and what other content I've found online seems to agree.
If not these, then make another suggestion for a higher-sensitivity 10" sub, that will work in a 1.25-1.3cu ft enclosure (mine is about 2.8 cubes, less sub and port displacement).
https://www.parts-express.com/dayton-audio-rss265ho-44-10-reference-ho-dvc-subwoofer--295-463
Recent YouTube Posts
