levee000
Levee000's Yukon Build
2008 GMC Yukon
JVC arsenal 4v Headunit
SSA 6.5 EVIL mids in front doors
Soundqubed deadener in front doors
Second Skin speaker tweakers
SMD dual ANL fuse holder
SSA EVIL 18"s D2--(2)
Ampere Audio 3800 @ .5 ohm
SKY HIGH wire throughout-
2 runs of 1/0 cca
1/0 OFC grounds and from battery to amp
4g ofc on subs an to amplifier
SHCA 1/0 inputs an 4g to 8g inputs
ILL CUSTOMZ battery terminals an 1/0 inputs
XS XP3000 battery
Knuconzepts RCAs
enclosure is 12 cubes before bracing an sub disp tuned to 29hz
Love the build man, how does it sound? What tweeters are you using in case I missed it.
Is this just a burp vehicle? I only ask cause I see your wired down to .5ohm. And if not how do those ampere amps do at .5ohm do they get hot, shut down, or draw a lot of current?
Stock tweeters for now.
No its daily musical build I wired low to account for rise. On stock electrical  I drop to 11.5 but that's when charging at 12.7 stock alt is computer controlled.
Beware where you get advice.  No such thing as rise.  ALL drivers have an impedance curve and if you play in the wrong spot you won't be happy.
Wow ! That's an ...evil setup ! You must be happy.
Down the road, you will be able to add a second amp for your subs.
How do you like  the mids : are they loud enough for all that bass ?
Thank you for grabbing the Evil's! :)
I plan on another amp yes for the subs. Need better electrical first lol.
Mids Def need more power but they do hang off headunit power.
I wouldnt count on that saving your amp. I never wire below recommended, unless it's a burp vehicle where you can adjust for rise playing sign waves.
Havent done any changes yet.  Yukon was wrecked a day after xmas. But not totalled.
Mechman 370 is on the way to fix voltage.
Oh man, when will it be back up and rolling?
bad news , but good news for the new alt !
Its fully repaired an driving. Alt shoukd hopefully ship this week. Have a show this up comin weekend i wanna attend
