UNIT 6639
Mach 5 15"
I thought I read some where that Mark was going to have a 15" sub available in the future.
If this is true, will it be DVC 4 ohm or will it be SVC 4 ohm? Whats the RMS going to be for it?
Hi Unit,
You're right, there will be a 15" coming. Its a finish to the MAW line so it will be a dual 4 Ohm (nominal) vc and 500 watts RMS power handling.
Here are the specs (from the manufacturer):
MAW-15
Fs = 24.6Hz
Re = 4 Ohm (both coils connected in series)
Qms = 5.06
Qes = 0.35
Qts = 0.33
Rms = 7.2kg/s
Cms = 0.18mm/N
Mms = 236.7gr
Bl = 20.4
SPL = 90.9
VAS = 190L
Le = 2.41mH
Xmax = 13mm
These may vary a bit as I take my own measurements when I receive the order. I select a few units randomly, exercise the suspension and test them before posting the final numbers on the site.
Best regards,
Mark
Hi Unit,
MAW-15
Fs = 24.6Hz
Qms = 5.06
Qes = 0.35
Qts = 0.33
Rms = 7.2kg/s
Cms = 0.18mm/N
Mms = 236.7gr
Bl = 20.4
SPL = 90.9
VAS = 190L
Le = 2.41mH
Xmax = 13mm
Best regards,
Mark
Thanks Mark, I cant wait until you get them in stock.
any update on the 15?
Hi Denim,
Nothing yet. I have a pre-order in with the OEM but the rep I deal with is away. Will keep you posted tho...
Best,
Mark
I ask because the 15 could be a big time mover for you. Many people shy away from 18s and want larger than a 12.
Hey! You stole my avatar!
I hereby condemn you to listen to Bose speakers at 125db for 24 hours!
That'll teach ya! ;)
Mark
dont know 2 much about mach5 products but that 15 looks like it has potential
80
4 Ohms nominal refers to the driver having a 4 Ohm impedance across most of its operating range. This is different from DC resistance which can measure anywhere from 1.8 to 3.5 Ohms.
Hope this helps.
Mark
When you say 4 ohm nominal, this means the coils are dual 4 ohm right :puzzled:
the sub is a d4 version. and the Re is the dc resistance, measured here with the coils in series.
Mark, will we be able to send in a deposit like with the 18? I would love to have a 15" or 2 paid for before or by the time you get them.
Or at least have a pair reserved, I have a feeling your subs are going to blow up and I mean that in a good way!
in appearance are they going to look similar to the 12's?
