Is there an agm battery that is under 7 inches tall that has the top threaded posts ? Need it for under the hood of my caravan
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 323
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 326
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 327
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 328
Do you have room to lay a group 31 or similar on it's side?
Dont think so. Its a real tight fit . Especially with the terminals im putting on.
I found a shuriken bt35 that I think yould fit . Its 35 ah and 900 ca. . Going to be really small and its a little over $100
Here is what I did in my TB, managed to fit a group 31 up front.
I was wanting to take out the stock battery tray and would be able to fit alot more but its attached to other things
depending on what it is you can always fabricate something, someone who can weld would be a plus :)
I could if I had a welder. . But what is connected to it is what the throttle cables come out of
Decided to go with an xs xp950. Should fit good
PC1200MJTPC1200MJT
