daviddto
4 DC lvl 5's, CRESCENDO, SINGER, 04 YUKON
What are you doing new to the enclosure?
I think hes going larger on the sealed...IIRC.  Looking to help his impedance curve.  Read it elsewhere...
Pretty much sums it up, more info on SMD.
Correct, I am making the sealed side bigger ( 9.47 before displacement ) . The port will be opened up as well, two subs inverted and two subs mounted regular. I was rising to 6.6 ohms and losing a ton of power. The cheapest route for me was to change with the enclosure. I will being having Daniel do a 6th order early next year for 6 15's.
Done a bunch of work the last month or so , I will post more updates soon.
Loading the box back in the Yukon
Started on the amp rack and that is where in at. I am going to get some work done on it this weekend.
I also put a suede headliner and visors in over the holidays
Looks good...
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 323
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 326
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 327
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 328
Looks good...
Thank you!
No Idea why the pictures are showing up this way
Thank you, here is a video I made 2 months ago. It is  on all four amps and doing pretty decent numbers now but I don't have any videos yet. . It was doing 149.9 door open mic in the kick the way it sat in this video.
This is the way it sit now. This was testing at a local shop with the drivers door open, mic in the passenger kick. We test when I first arrived and it did 154.5. After some re wiring and testing, these was the results.
Edited by daviddto
These are just burp numbers, I have not tested music yet.
