B00Mbap
Subwoofer Recommendations (For output)
Hey everyone I signed up here awhile back, but have only been able to lurk here and there. Anyway I'm gonna pull the trigger soon and get a sub stage, but I'm not sure which sub/subs I want to buy. My new sub stage will pretty much be 2 12's in a ported box or maybe one 15 in a ported box depending on how much room I have or don't have..
I've looked through the 12'' subs in the store section from all the brands and a couple of 15's but leaning more towards 12's. My goal for the sub stage is pretty much output/loudness. I need some help/recommendations from you guys please and I'll provide more info if you guys need to know anything else.
Sidenote: Car is a 2011 Ford Fusion SE
Thanks
errr, like ALWAYS.  Space first.  Can't shop at all until you define that.
lol....this^^^ and a budget
XD
How did I forget those two things lol
Ok trunk dimensions....
Length: 38''
Width: 51"-56" (trunk caves in at one spot)
Height: 22"
Budget for subs....
Up to $400 for 2 12's or 1 15 but willing a bit over that number if needed.
Sidenote: Setup will be a daily setup and the music type is mostly hip hop.
Edited by B00Mbap
DSS Ethos 15" :D
Edited by SpeakerBoy
Saw those things on youtube a few days ago. They look sick!
Still deciding though but that's a good suggestion I'll keep in mind coolugh.gif
Edited by B00Mbap
I recently finished an install for my buddy with two DSS Ethos 12". The enclosure was less than 4 cubes tuned in the low 30's iirc. For output and sound quality the DSS Ethos are an excellent choice. Their low end extension playing rap is nasty. I know two 12" Ethos are over your budget. One 15" in a proper enclosure and good power will fit your needs for sure.
Yea I also saw a vid of those on youtube and they look like they would definitely do the job, but yea out of my price range. But like I said before its possible I might go with one 15'' Ethos with the recommended specs/tuning.
Just gotta find a good amp to power it and then get electrical up to par.
Still taking suggestions in the meantime....
Edited by B00Mbap
Going to be hard to get as much bang for the buck other than the ethos.  maybe check out the FU subs.  TaylorFades 12" shootout he liked them second to DSS out of the subs he tested.
How much power you looking at running?
Never heard of FU Audio but I'm checking them out.
Power wise I'm looking at 2,000 RMS max
Quentin gives a different power rating for his DSS subs. They are not rated thermally but by how much it takes to takes to reach xmax in an enclosure spec sized, tuned to 32hz. Which is 1800 watts. It will thermally take more but I would run it in a modeling program to find out what you could do.
i think you should do 2 sundown 12s zv3s and put some power on them and be happy
Nah they're nice but they'd be over my sub budget.
If I did go with Sundown 12's they'd probably be sa-12's. Haven't looked at their 15's yet.
Plus there's a Sundown dealer near me (well not really kinda far away) but I can talk with them too about what I want.
Edited by B00Mbap
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 472 views
        • 1 comment
        • 689 views
        • 1 comment
        • 235 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,116 views
        • 8 comments
        • 2,044 views
        • 1 comment
        • 195 views
  • Similar Content
    • By TLOTIS
      I’m looking to build a ported enclosure for (6) Ampere Audio AA-2.5 6.5” D2 subs. They will be run on a 5k/1 ohm stable amp wired at a 1.33 ohm load. There will be plenty of power as they are 500 rms and 800 max.  I can’t seem to get anything from Ampere Audio on the port size I need. With sub displacement my box needs to be 2.48 CF (+) port displacement. Does anyone have suggestions or know how to calculate the port size? Square inch and length is what’s needed. Hopefully someone can help on this
    • By Ryann627
      Thanks in advance guys.
    • By Aaron Clinton
      A brief introduction to the all new SSA Demon, but first a farewell to its predecessor.
           Our very long running SSA Dcon has ridden off into the sunset, or at least taking a breather.  The SSA Dcon was our second subwoofer model we ever launched.  At the very beginning, we had the Icon and as it gained traction we saw there was a need for a pure SQ sub of more modest power rating than that the Icon.  So in early 2008, the first SSA Dcon was launched.  (The Xcon followed shortly after).  That being said, the Dcon was almost an immediate hit, with a long 2" copper coil (rarity to have one made in the USA) triple stack motor, rear vent.  The Dcon was very affordable, well made, quite efficient, clean across the entire range, and flexible with enclosure demands.  It is interesting as there are some SSA Family members who swear by their Dcon and will not give it up ever.  (It even became a favorite of some of the home audio crowd).  All that being said, the Dcon evolved a bit for its second generation, we made a leap forward in motor force moving to what is best described as a scaled down Xcon motor, with a large single slug, solid pole, and deeply bumped back plate, while beefing up the suspension and leads.  We were able to bring the power handling up 33% while not hurting the sound that made the Dcon successful.  There was a stretch of a few years, before we ran out of stock, that the SSA Dcon 12 was our all time best selling subwoofer.  So its existence was very important to SSA.  Well with changes in the market (read:customer demands and amps getting much cheaper), as well as sky rocketing material costs, building the Dcon in the USA no longer was an option, so production stopped early 2017 for both the Dcon (and Gcon) and inventory ran out later that year.
           Late last year, due to the long lay off with out the Dcon (and Gcon), we started development of an updated Dcon at a new build house.  The quality and performance of our SSA Evil1 tweeters were above our expectations, so we decided to send more production to that same build house.   As we saw that the market slowed overall for modest power rated subs due to power getting cheaper and people wanting higher power handling subs, so the market began to really start heating up in the 500 - 1200 watt range, I knew we needed to address it.  There is an 8" model developed, but it will not make it this first production run.
           The new model had to handle more power and have more xmax while not sacrificing the balanced and clean sound the Dcon had established for nearly a decade.  That meant larger motor, larger coil, more suspension, larger leads, thicker cone, taller surround, etc.  In the end, all of the changes that happened to the over all design, we could no longer call it a Dcon.  In sticking with the theme of the Evil, a model name that has become so well known, while respecting the Dcon, the Demon name was selected.  The Demon is a great blend of the previous Dcon and Xcon, both in design and appearance.  In prototype testing, the SSA Demon thrived smaller to mid-sized ported and mid-sized sealed enclosures.
      Quick SSA Demon stats:
      2.5" copper coil Aluminum former Aluminum Shorting ring Solid pole, non-vented bumped back plate Large single slug motor Pressed pulp cone Tall roll surround Push terminals Dual Nomex progressive spiders Stitched tinsel leads Large dome dustcap I will list T/S specs and enclosure recommendations shortly.  We are very excited about the SSA Demon as it bringing back to our line up a pure sound quality subwoofer that will be affordable, while still having the characteristic SSA warmth and output.
    • By DedicatedEnthusiast
      B2 Audio X2C 15
      $650 shipped!
      Contact at 440-915-2309 for further questions/concerns.
  • Recent YouTube Posts
