Blackwell Marc
CRESCENDO AUDIO BC5500D back panel vibrating noise its really startin
CRESCENDO AUDIO BC5500D  back panel vibrating noise its really starting to bug me is there any fix?
Yes but more information would help like what's causing it, where is it mounted, etc. Hard to help with no information given
Show a pic if you can too
Did you remove the back panel before to look at the guts causing the screw threads not to hold as tight? See there could be multiple problems
i had the same problem, it's the back panel against the heat sink. I took it off and put some foam tape down the sides where it makes contact, problem solved.
use Blue thread lock bro if its coming loose on the screws, but i agree with everyone on this post says , check wuts causing it first
Edited by Cruz87
Probably the best idea. I've used deadener too.
:WELCOME:
