97maxima
Trunk 4th order build
Yanked everything out of my trunk and am awaiting recones and baskets to build my 15s to 12s. Cutting down on weight and going back to cap banks, 6 banks of 6 3000F Maxwells. Laid the floor in with 2 cans of foam and fastened it down. Going to wait a few days to see if i have and major buckling from the foam before i proceed with building the rest of it. Will all be built in trunk. Have a ton of Kreg jig tools to get the job done. Will still be running my Tara HD 8000 till and if the HD 10k comes then ill swap them out. Car tends to like a lower peak and it was brought down a tad lower after using another bulk back on my doors. So ill do some MECA with it this coming season.
7589_10203112420957535_35550529502768910
Dropping almost 300 pounds of batts should help with the squat i had going on in the rear.
186a8f54-52ce-4f66-b01f-9cb96de3f3a5_zps
Edited by 97maxima
nice!
nice!
Thanks, going to build up the side walls Saturday since the foam has stopped creeping and seems set. Hopefully it will be playing next weekend
Good luck with the build
nice !!!!
Putting in the majority of the work today on my 4th, going for 1 to 2.75 ratio. Could go larger or smaller. All of it will easily be modifiable tho. Dry fitting it now and using a pocket hole jig more the majority of the build. More pics to come after i pickup a few more 2x4s
10599221_10203138501089522_7238197410853
:popcorn:
Moving right along. Nearly 10 cubes inside the shell and that's stopping short of the back seat opening. Have the baffle to build tomorrow and the lid.
1016471_10203140354575858_29070455755495
10600663_10203140354815864_4360002755329
Well wrapping up the build in the next few days. Have to prime the front chamber, finishing gluing the subs and load then and then i can build the loading wall. Otherwise its wired minus some Shca ofc 8 gauge im waiting on for sub wiring. After its finished ill be working towards swapping out my last few batts for cap banks and may do a alt and amp upgrade.
10271586_10203160952250787_8290732762634
10730807_10203161010492243_3592363835217
1511171_10203160952370790_24823486175545
10557191_10203156087849180_4182031691635
10423909_10203165538965452_8412771337668
10731213_10203165539085455_5819677367981
Looks badass so far :woot:
Looks good is that 4/0 welding
Thanks
Its all 2/0 minus the alt runs to the rear which are in 4/0
Hell yea!!!!!
Looks pretty good!!!
I didn't know a red Dss logo on the dustcap was an option, looks good!
Anything is available to be customized, so if Q didnt do them himself you could get them done yourself.
 Red nail polish. Roughed up the silver with fine sandpaper and cleaned it up with rubbing alcohol .
looks killer man!! god i cant wait till my Ethos come!
How did it model with both tunings?
Never modeled anything just built and shrunk the loading wall down. it plays decently flat from 30hz peaking at 44 and remains strong thru vehicle res.
