WTF!!! Bronco Big 3
By
ObTechAudio, in Amplifiers / Head Units / Processors / Electrical
Recently Browsing 0 members
Recent Topics
- 7 comments
- 352 views
- 1 comment
- 447 views
- 1 comment
- 175 views
- 1 comment
- 154 views
- 3 comments
- 1,016 views
- 8 comments
- 1,932 views
Similar Content
By joe79
I will try to post pics soon. The question is has anyone ever installed the big 3 on this model of a vehicle. 2009 Ford Explorer 4.6Lt? I have been looking at my electrical and there is ll kinds of run offs from the positive wire from battery. There are 2 that run from positive into the fuse box, and at least 2 more that split off into I haven't found where yet. Seem like a lot. My question is would it be OK to keep those running to where they are going and still run 0 gauge from Alt to battery using a bus bar or similar? Also with the ground question there are several split offs from the ground battery terminal to the chasey, should just through those on top of my 0 gauge ground?
Thanks
By fearlessgangsta
So Shizzzon got my attention with some cheap 4/0 gauge he got. I'm thinking of adding a couple of 4/0 grounds and a couple 4/0 runs from alt to my front batts. I have never worked with the stuff before. I will be upgrading my alt to a 400 amp eventually so I'm trying to plan ahead.
Since the length of these runs will be shorter than 6-7 feet will there be any benefit vs 0 gauge?
Is there a way to fuse 4/0 wire?
Also what lugs do you use for your 4/0 wire the only ones I found have a minimum buy amount of 10?
Recent YouTube Posts
