Julian
Chevy Trailblazer (4) ZCON 15s 6th order bandpass, taranp's, etc.
Hey, be careful with this recone ok. It has already been broughton attention to Mark from Zack when we were all at world finals. Basically, the spiders seem to be shorter. As you can see. So when under high excusurion, the leads and touch the basket which could cause a short. just an heads up.
Gonna heat shrink them when I solder the leads.
great idea
The box is going to be 15.5ft^3 tuned to 30hz for the rear chamber, and 24.5ft^3 tuned to 50hz for the front chamber. The entire box is double layered with the sub baffle quadruple layered and front of box triple layered. The overall dimensions are 37.75" wide x 35" tall x 72.25" deep. Everything but the front is going to be sandwiched between the top and bottom pieces, so naturally everything between them will be 32" tall.
Instead of buying a new alt for the dual alt setup I'll be using the old alt out of the mustang, going to convert it to self exciting and fabricate a bracket, whenever I get the money I'll replace the factory alt with a new mechman.
I need to figure out how I'm going to cut .25" steel, lol.
Plasma cutter would be nice !
dude, I Phucking love your wall design!
Yeah same here
Yeah same here
Thanks guys, Ryan took in my wants and needs and this came out.
Need to get the lumbar for this now
A variable speed jigsaw with a 24 to 18 teeth per inch blade and some ATF for cutting oil will get the job done through 1/4" steel. Looks good.
There is a posibility santa will be bringing me an Eastwood plasma cutter. So i'll use that for the brackets.
Here's something I've been working on after work for a little something. It's my old mechman 320 from the mustang. I finally finished it up for the most part. Just need to drill some mounting holes and call it a day.
How about this for an update?
Over about 12 hours all of this was done.
Shit just got real, makes the enclosure i built yesterday look pathetic.
Still need to finish the baffle and the front of the wall. Lots of work to do, waiting on some bars from Steve mead, and need to order some random.bits
What color are you gonna paint the inside
can't wait to see this playing!
Nice update Julian.
Any updates
knock knock
Who there
I've worked every day for the last two and a half weeks so I haven't had much time. I started off by installing my spare 9887.
