PHATBOi
2 Sundown X18 & 2 MB Quart DSC1500.1D Build
New Amps.
Temp mids/highs setup till the box gets built.
Subs.
First family photo.
Kids are excited as I am.
Son wanted to show me he could lift it.
Box:
13^3 @ 30Hz with 168 sqin of port @ 13 sqin per cube
What was the reason for the way you did the port?
What do you mean?
Very nice. You going to paint the box?
Thanks. Yeah, probably bed liner. It'll get done before Slamfest in September.
  On 6/15/2014 at 9:56 PM, PHATBOi said:
What do you mean?
Iv just seen some people recently doing that same style port and was wondering if there was a reason behind it. . Is it just because of space issues with the subs or something?
Why does it seem weird to you? Its a port
It doesn't seem weird, I'm asking if there was a reason. . I try to learn everything I can about audio. My bad lol
And a port is not just a port. There is usually a reason for a certain way someone does there port
Edited by frogcase2002
Didn't want a long skinny port across the bottom and didn't have the width to do a center or side port so this is what I came up with. May end up shrinking it. Have to wait for the subs to break in and see. Really lacking on the low end right now. Plays it fine and the subs are moving good, but there's just no authority behind it. May try to block off the open area, where my batts are, under the box in the back. Think maybe it could be losing it there also.
Edited by PHATBOi
The Plan:
First thing I'm gonna do is pull everything out and put the third row seat back in then fold it down flat back into the hole where my batts currently are. This will give me a solid floor for the box to sit on and port to fire over. I think that will force a lot of lost output back into the cabin.
If that still doesn't get me to where I think it should, next I will try turning the box around and firing the port into the cabin.
Last resort, cover the port and drop 3 8" sonotubes in the top baffle, opposite the subs. At 12.45" a piece, they will give me around 150 sqin of port area and a tuning of 28Hz.
Before the teardown last night
Found out why my voltage has been so low, that's my front batt
So this happened
And this is what it looks like now
Putting this seat back in made all the difference in the world. Port is now loading off the hatch instead of dumping into the open space that was under the box. Brought the lows out!!
Pretty cool what just moving around some stuff can help lol
Yeah, I'd say the lows have definitely come in. The great thing about it is it still hammers the higher end also.
Seems like a lot more flexing
Sealed up legal on the dash 34Hz burp
Driver's side rear sliding door open 34Hz burp
driverssideslidingdooropenburp_zpsdb336c
Sealed up legal peak hold on music, Decaf- Dirty Bass (33Hz)
My only goal was to break a 45 on music. Mission accomplished!!
Need to stop the flex in my roof and rear hatch. I'm sure I'll gain once that's taken care of.
