tc300
FI Q motor 08' ish
I got a F I Q motor with BP option from around 08' era. Would a zcon or a xcon recone fit in it..????
The coil length on the Q is just shy of 2.5". I know either zcon or xcon has similar length..
Why wouldn't you use the correct parts. Fi builds both subs anyways
A zcon recone does not make a zcon. You're better off ordering straight from fi
The newer Fi Q recones will work. You will be happier with just doing that. Just include in the message box that its for a pre-09 motor.
What are the differences between newer and older soft parts??
What are you trying to do?
