randeez
ported sub-floor
Just make the flush-mounting ring attatched to the sub, that way you can take out the ring with the sub by pulling up on the ring.  Glue the ring to a separate thinner ring that also fits under the sub.  If you put a really thin bit of foam under the thinner ring, it should remail airproof if your screws/bolts are tight enough.
