Followers
0
Recently Browsing 0 members
Recent Topics
- 7 comments
- 254 views
- 1 comment
- 216 views
- 1 comment
- 92 views
- 1 comment
- 80 views
- 3 comments
- 938 views
- 8 comments
- 1,854 views
Similar Content
By jcarter1885
By Joshdashef
Hello and welcome to my daily headaches! I'll start this build log off with my past setup, my current, and finally update throughout December as I work on probably the furthest this little Civic will let me go.
My instagram: https://www.instagram.com/joshdashef1/
The Past Build:
Head unit: Pioneer 80 PRS
Mono Amp: Rockford Fosgate Prime 750.1
Subwoofers: Rockford Fosgate P3D4 12" (two)
Kicker 4 gauge amp kit OFC
Stock Electrical (alternator included)
Did do the big three sometime between here and current build
Prefab Box: Q-Power Box (Dual 12s)
Tips: Tesa taping RCA's, Marking RCA's Low/Mid/High or similar,
Big Three with loom. Wire was Sky High 1/0 OFC with some 1/2" loom I believe. Old military style terminals (DO NOT USE THESE) they cracked my battery eventually.
By mklett33
Hello and welcome to my version of the “How to Build a Custom Subwoofer box Tutorial”. This tutorial aims to teach you not only how to create a subwoofer box but how to add additional styling and design to make it a one of kind masterpiece.
This is a four part tutorial series; a brief description of each part is given below and accompanied with a video and pictures. Enjoy!
Part 1: How to Build the Box
In this first video I cover the basics of a box design, incorporating bracing and 45’s and construction techniques.
Part 2: Customizing the Box
This video covers the design and production of custom template created insert shapes that mount to the front of the box and can be used to accent and tie to other parts of the install. These techniques can be used on other aspects of your install like custom door panels, and more.
Part 3: Molding the metal mesh
Molding metal grill mesh gives a very custom look to our box, you could use this technique to hide a port, or protect the speaker itself.
Part 4: Wrapping with Vinyl and Carpet
In this final video we finish the custom box by wrapping it with carpet and the template shapes with vinyl.
Thanks for watching and learning! Now that you have learned these new techniques what would you use them on?
Recent YouTube Posts
