DedicatedEnthusiast
Best Head-Unit for expensive sub-stage and bass alone (NOT mids/highs)
Looking to upgrade my entry-level pioneer DEH-14UB Head Unit IF it will make a worthwhile difference in output or sound level mainly on my sub-stage going with a 4-6v pre-out upper-class pioneer, kenwood or alpine deck. Tell me what do you guys think? I already have the entry-level pioneer wired to a clarion MCD-360 crossover with 5v max output voltage so am I really going to notice a difference in the bass production from the subs or no??
All comments and opinions are appreciated thanks:)
Are you just wanting more output or are there features you would like to have with the head unit. . . . I don't think you would see a big difference unless something is wrong now that another hu will help
More detailed bass response with better Equalization and crossover capabilities ?? Sure you should be able to tell the difference if the rest of the system is up to par with the headunit.
But if you are simply looking for "balls to the Wall" more output ?? No, don't think you will see any difference.
You may want to look into stronger amplication / battery power for that. increasing pre-out voltage will not help you get "better Bass"
My Kenwood 9980 (at the time of pruchase, one of the best on the market) only had a max of 4 volts output.
Best of luck with your search on this.
Edited by Randal Johnson
There is no best head unit for sub bass only, any h/u with a sub preout will do the job just fine.
Edited by jay-cee
Won't help, neither does the mcd. Voltage from a 1v deck is fine.
The preamp voltage has nothing to do with loudness, higher bass output, etc. A higher preamp voltage increases signal to noise ratio of the signal of you are picking up noise during signal transmission, that's basically it.
The ONLY difference a a new head unit could make for your goals is improved equalization or crossover features if you have a dip in the bass response somewhere to help even everything out. Otherwise the SPL of your system is going to be the same no matter what HU you have, from a Walmart brand to a top of the line unit. Makes no difference. Aside from EQ the head unit has no means by which to increase the output of your system.
Why do you have the Clarion crossover?
Thanks guys! I was mainly wondering if output could be gained but im glad to know that what I have now is just fine and impious I have the clarion crossover to further cancel out undesired higher frequencies in the bass response which crescendo told me is completely normal to exist to a certain degree reguardless of filter settings on the amp
bs. the amp crossover should do that job just fine.
Well, yes, that's the way a crossover works. It isn't a brick wall. A crossover attenuates the frequencies above the crossover point at a certain rate, known as the slope. I'd be surprised if the crossover on the amp didn't do this job satisfactorily for your system. On the other hand it sounds like your system is all bass, so even with the crossover set the output at those frequencies from the subs is still well above that from the speakers.
Thats what I originally thought lithium but impious are you saying this can be expected? Again its not like the higher frequencies are full blast or anything but definately annoyingly noticeable to a degree when it causes rattling and such
that's a sound deadening issue is it not? what do you mean when you say high frequencies are causing rattles?
http://www.bcae1.com/xovrslop.htm
Read the link for a basic understanding of how a crossover works. Yes, the frequencies above the lowpass crossover frequency are still there, they are just lower in level compared to the frequencies below the lowpass crossover frequency. If you have a system with a powerful substage and ver weak midbass, which based simply on your thread title I'm going to assume you have, then yes the frequencies above the crossover point will still be played at a very audible level by the subs.
That 'nendo amp probably has 12db/oct crossovers. So if you are playing the subs at around 135db with a 50hz crossover, and the response above 50hz is relatively flat from the sub, then at 100hz you are still going to have 123db from the subs. At 150hz you are still going to have 111db. That's probably 10db or more louder than your speakers. In other words, at 150hz the sound from the subs would be twice as loud to the ear as the sound from your speakers. That's hypothetical of course, and ignores a few things, but the point is if you have a huge sub bass system then yes the output above the lowpass crossover is still going to be substantial. And having weak speakers is going to make,the "problem" appear even worse.
i would hope crescendo used 18 or 24 db/oct filters on an amp of this size. what impious is saying would still be true either way.
Edited by lithium
Lithium I just mean that the higher frequencies I have set to be tuned out are still so present that they cause annoying rattling in my rear deck area. Thank you VERY MUCH for your input impious and back to lithium only crescendo would know I don't remember the details of what I was told besides that I could purchase the clarion mcd to further reduce undesired upper frequencies. Also I do remember the slope impious had mentioned being explained.
I tried to look up what filter is used but they don't advertise it. Weird. Impious covered everything. But u should also consider some deadening as well. Give sounddeadenershowdown.com a read
When I googled it a couple manuals showed up and the text displayed on the google search said 12db.
So what does that mean? Would 18 or 24 have been much more suitable?
Suitable depends. Just more roll off.
I see. Well again this is the reason why I purchased the clarion crossover, for more roll off which is more suitable for me:)
More isn't always better.
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 472 views
        • 1 comment
        • 689 views
        • 1 comment
        • 235 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,116 views
        • 8 comments
        • 2,044 views
        • 1 comment
        • 195 views
  • Similar Content
    • By TLOTIS
      I’m looking to build a ported enclosure for (6) Ampere Audio AA-2.5 6.5” D2 subs. They will be run on a 5k/1 ohm stable amp wired at a 1.33 ohm load. There will be plenty of power as they are 500 rms and 800 max.  I can’t seem to get anything from Ampere Audio on the port size I need. With sub displacement my box needs to be 2.48 CF (+) port displacement. Does anyone have suggestions or know how to calculate the port size? Square inch and length is what’s needed. Hopefully someone can help on this
    • By Ryann627
      Thanks in advance guys.
    • By MJS_IraggiAlts
      PRV AUDIO Vocal Speakers....
      This may not make sense initially, but a high-quality speaker will have less bandwidth than a lower quality speaker... (for the most part)
      Just like a 3- or 4-way system is always better than a 1- or 2-way system.  The narrower the bandwidth the speaker must play the cleaner it will sound.  This will also keep you from asking the speaker to play up to its upper and lower frequency limits which are where it starts to sound "forced" to play those frequencies
      Pro Audio speakers are nothing new to car audio, but I see consumers not really knowing how to properly use them and having some issues which is understandable.  These are totally different than your standard coaxial speaker
      If you look at the graph on the 6mr500ndy, which sounds amazing, you'll see that it can play from 90hz to 12,000hz... but if you narrow it down to what is plays "best" and more "naturally" it’s closer to 200hz to 10,000hz.   Yes, it can play down to 50hz but not efficiently and not as well as 200 and up. Very low volume that would be fine but in what we do with the speaker you will want to cross it over closer to 200-300hz
      I get a lot of PMs asking if this speaker will pick up where my subs leave off?   … around 60-80hz.  I say no but the specs say "yes”. 99-13k so that may be a little confusing if you don’t look at the graph and understand what information it has in it
      So, for someone interested in using this speaker as a voice speaker, which I HIGHLY recommend, you will also need a "midbass" speaker to go with it such as a 10mb800 or 10mb500 or 8mb450.
      This leads me to another piece of information.  PRV model numbers have an "MR”, “MB", "SW" or "W" in between the size of the driver and wattage of the individual speaker. MR=midrange
      MB=midbass
      W=woofer
      SW=subwoofer
      This is a general guideline for what the speaker is geared towards. That doesn’t mean an 8mb450 can’t be used for midrange or and 8mr400 can’t be used for midbass.  That is where the graph and interpretation of the graph comes into play
      There is a lot more that goes into designing your front stage or your "voice" speakers that one of these days I’ll try and have a more in depth write up.   The possibilities are endless...
    • By musgrove
      I'm nearing the finish line in an installation that includes a new HU with FT/RT, FR/LT RR/RT RR/LT, and a SUB output, plus an unmarked, unidentified in the manual, RCA output on the back of the HU next to the SUB output.
      I have a 5 channel amp that has Channels 1(white), 2(red), 3(white) and 4(red) marked clearly on the amp, plus a SUB RT(white) and SUB LFT(red) input, all input by RCA.
      The same amp has 4 sets of output terminals, 1 each for + & -. It also has 2 terminals for the sub (+ & -), which connects to the sub on R &L posts.
      So, first question:
      How do I run a cable from the HU, which is 1 RCA connection, to the AMP, which has both LT and RT RCA input connections?
      Second question:
      I also have the White, Grey, Green, Violet (+&-'s) hooked up from the HU to the wiring harness that goes to the speakers. The reason for this was that I have six speakers placements: 2 6.5" in the front doors, 2 6.5" in the rear doors. In the dash, I removed the tweeters that were in a plate and replaced them with Infinity Kappa20's midrange speakers that have bandpass crossovers that handle 550hz-7Mhz hooked up.
      Just to confuse things more, The manual for the amp shows The channel 1 speaker attached to the channel 2 output terminals(+&-) and the channel 2 speaker (+&-) attached to the channel 1 terminals. Channels 3 and 4 are where I expect them, 3 & 4. And then again for the SUB it has + and - terminals to go to + & - posts on the SUB.
      I've routed every plug in every location and checked each speaker, one by one by changing the fader/balance in different combinations to determine what's going on.
      What I sense I'm doing wrong is that I'm wiring RCA cables with both RT/LT wires into the AMP to the HU when both only want a single signal cable each going into each jack. One single wire each that somehow is carrying both the Positive and Negative in it, versus a double speaker wire that goes into a positive/negative RCA male connector.
      So that leaves the sub with one single output HU going to the AMP which has a R(white) and L(red) female connector. And then the 5th channel +&- going to the +&- on the SUB input.
      The reason I have the HU output speaker wires (white,grey,green,violet) going to the speakers is because of the Dash Unit speakers. They're tapped into those 4 in the wiring harness where I can't get to them, but run from the HU from 4 wires to 6 different speakers). Again, the dash speakers are 2" Infinity midranges with bandpass crossovers connected to each which came with them. I just noticed they are 2.5 ohm, and everything else is 4 ohm, which is worrisome.
      Is there a wiring genius out there that can understand what's going on and tell what I have wrong? There's also a whine coming from the front right dash speaker and possibly the right(passenger side) door speakers. I have the power cable far from the speaker wires on either sides of the vehicle. But I'm sure it has with the larger wiring issue at hand.
      Any and all help is greatly appreciated. This is a crazy puzzle. Here's a diagram I made to make it more visual:
  • Recent YouTube Posts
